Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: 4l80e tcc throttle close cax
  1. #41
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Thank you
  2. #42
    Feb 2012
    Quote Originally Posted by Tinbender59 View Post
    Just a heads up, my truck kicks the TC out when i let off lightly as in going down an overpass. And when i run over 73mph. The DTC codes says cylinder missfires and cylinder#7 missfires. I have chased everything electronic finally put a stethoscope to it at #7, oh my heavens!!! Ive never heard such a noise from a "good" running motor. Gotta get in there asap. Check your misfires??
    I never got around to looking into the issue the project got put on hold , I think it was a ECM issue or the tune file was corrupt because commanded timing kept going to 60 degrees.
  3. #43
    Feb 2012
    Now I have a different project going was wondering if somebody still provides a service to have the tcc locked at 0% tps and also have the ability to hold first gear in manual low and not upshift to 2nd . Would be willing to pay a small fee as well just want to get it sorted . Its a 2000 ECM with 512 kb memory . It just sucks efilive doesn't do anything about it since both features are available on HP tuners. Thanks
  1. 4l80e TCC trouble
    By rossp in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 26th, 2014, 06:25 AM
  2. 4L80E TCC AppEn Mode
    By turbo_bu in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 12th, 2010, 12:09 PM
  3. 4L80E TCC problem
    By Arnoldi in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 19th, 2010, 11:26 AM
  4. Knock Retard On Throttle Close
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: February 13th, 2008, 08:44 PM
  5. 4l80e TCC problem
    By Stoichiometric in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 28th, 2007, 08:04 AM
