Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: 4l80e tcc throttle close cax
    Jan 2013
    Default 4l80e tcc throttle close cax
    Hi,
    I have seen other threads where Taz mentions having the addresses for the 4l80e tcc lockup tables and was wondering if there is any plan to release a cax for these?
    I am building my harness now and would prefer to run the 4l80 wiring but would like the lockup on closed throttle.
    I'm using cos5 for the 12212156 os.
    Aug 2006
    Post your tune when you are ready.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Oct 2005
    I could use this fix as well. My TCC is repeatedly locking/unlocking if cruising at around 20% throttle. TCC tables are basically stock 80E tables.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Aug 2006
    Hhmmm, I'm having laptop, .ctz issues. Let me get this sorted out.
    Jeff
    Aug 2006
    Hey Drx. Try this out.
    Oct 2005
    Got it. Thanks.
    Jan 2013
    hi,
    could you apply the fix to my tune please?
    thanks
    TT_80e_53_0069.ctz
    Quote Originally Posted by TrendSetter View Post
    hi,
    thanks
    TT_80e_53_0069.ctz
    Send Lextech a pm and ask him nicely
    Aug 2006
    Hey Dave, (Trendsetter) Here is your altered tune.
    Jeff
    Jeff, thanks.
  1. 4l80e TCC trouble
    By rossp in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 26th, 2014, 05:25 AM
  2. 4L80E TCC AppEn Mode
    By turbo_bu in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 12th, 2010, 11:09 AM
  3. 4L80E TCC problem
    By Arnoldi in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 19th, 2010, 10:26 AM
  4. Knock Retard On Throttle Close
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: February 13th, 2008, 07:44 PM
  5. 4l80e TCC problem
    By Stoichiometric in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 28th, 2007, 07:04 AM
