got it, Thanks jeff
got it, Thanks jeff
Lextech, can you do the same for me please?
Thanks, Brent
2000 C5 FRC, some stuff.
2006 TBSS, more stuff.
Here you go.
Jeff
98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
Works like a champ...thanks again Jeff!
Would really appreciate if you could modify my tune Jeff. Its a pain with a high stall triple disk converter locking in and out thanks.
Dil
Hi Dil,
I don't have the parameters for that Operating System. If you tell me what year it is based on and I can try to see if I can figure it out.
Jeff
Ok, I looked in the COS tutorial and saw that it is based on the 12579405 Operating System. I added the parameters for that. Here is your calibration.
Jeff
That was quick , thanks Jeff, much appreciated . I must be really dumb or I've had a long day at work, but I cant find the parameters in the uploaded tune . I looked under trans and tcc tables couldnt find anything . Could you please point me in the right direction.
You won't find the parameters by viewing your calibration. They have been changed but won't appear without the appropriate .cax files installed into your software.
Jeff
