Results 21 to 30 of 46
Thread: 4l80e tcc throttle close cax
  1. #21
    Jun 2008
    Hey Lextech, Could you upload the cax files for this? If not could you apply this to my tune?
    09_18_17_E85.ctz
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
  2. #22
    Aug 2006
    Hey John,
    Here you go.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
  3. #23
    Jeff, thanks.
  4. #24
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Jeff is the Man of the hour, sent him mine and got it back the next morning. thanks Jeff
  5. #25
    Feb 2012
    Hey Jeff , you modified my tune a while ago , I still can't get the converter to stay locked when I get off , can you please take a look at it again . Sorry to bother you again
  6. #26
    Aug 2006
    Quote Originally Posted by PSI View Post
    I lowered the settings a bit. See if this does the trick.
    Jeff
  7. #27
    Quote Originally Posted by Lextech View Post
    Jeff
    Tried to send it thru a PM.. here ya go..
  8. #28
    Aug 2006
    Here you go.
    Jeff
  9. #29
    Here you go.
    Jeff
    Anything special I need to do? I flashed it In and still unlocking under 5% TPS.
  10. #30
    Aug 2006
    Hhmmm. Try this. I lowered the MPH a bit.
  1. 4l80e TCC trouble
    By rossp in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 26th, 2014, 06:25 AM
  2. 4L80E TCC AppEn Mode
    By turbo_bu in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 12th, 2010, 12:09 PM
  3. 4L80E TCC problem
    By Arnoldi in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 19th, 2010, 11:26 AM
  4. Knock Retard On Throttle Close
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: February 13th, 2008, 08:44 PM
  5. 4l80e TCC problem
    By Stoichiometric in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 28th, 2007, 08:04 AM
