Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Update: Jan 2015
    Default Update: Jan 2015
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Notes:
    Known Issues:
    Check for known issues here.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 275
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 269
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Firmware, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.76 (Jan 27, 2105
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Senior Member DieselMafialb7's Avatar
    May 2012
    Thank you! !
    Nov 2009
    It's go time :-D
    -Kory
    http://www.PPEI.com/
    Dec 2013
    Awesome!!!
    Aug 2014
    Yay!!
    Member Dirktdolman's Avatar
    Oct 2014
    Does "Check for updates" work? The reason I ask is I just tried it and it says I have the most recent version, but the "About" in 7.5.7 says I have build 269 and 8.2.2 says I have build 263.
    2003 Chevrolet Silverado 2500HD 6.0L Automatic 4 X 4
    Nov 2009
    Quote Originally Posted by Dirktdolman View Post
    Not for snore public release. Download and install manually from here and it'll be good to go!
    -Kory
    Oct 2014
    Snore public? LOL It is all good now. THANKS
    May 2010
    Thanks A lot
    EFILive Tuner
    Junior Member DMan1198's Avatar
    Dec 2014
    Hooray
    Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, s480, traction bars
    The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper,
  1. Jan 17 RC2 Problems
    By ScarabEpic22 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2010, 11:57 AM
  2. BB Logging Update Jan 07, 2008
    Last Post: March 9th, 2008, 11:32 AM
  3. LB7 / LLY .cal file update - 08-Jan-2008
    Last Post: January 13th, 2008, 09:56 AM
