Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: Update: Jan 2015
  1. #31
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Just out of curiosity...who makes the E80 and what it is it used in? A new DI ECM?
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  2. #32
    Quote Originally Posted by GabrielMga View Post
    GM Gas E80 engine controller read/flash support (*Note: Parameter mapping not available).
    Is there a way to modify this reading? Or is it encrypted?
    All files read with EFILive are stored in our own .ctz format for a number of reasons, there is a lot more data saved in to the .ctz file other than the actual contents of the ECM.
    Quote Originally Posted by DURAtotheMAX View Post
    Made by Delphi, not presently used in the US though, but yes 'another' DI ECM currently on some 4 cylinder cars. Same story of ECM evolution, more memory, more CPU power. I suspect it is probably the replacement for the E39 series which is now 5 years old, so the time cycle for replacement seems about right.
  3. #33
    Nov 2005
    You'll find the supported vehicles listed on our flash only supported vehicles page, https://www.efilive.com/flash-only-supported-vehicles.
    Fwiw, at this point it's only in a Chinese built Buick at this point.
    Cheers
    Cindy
  4. #34
    Lifetime Member bobo's Avatar
    Nov 2005
    This version of the EFILive Tuning Tool has not yet been
    configured to display this controller's operating system.
    This may occur if...
    your controller has been updated by a GM dealer
    to fix a software problem.
    OR
    you are attempting to load an EFILive custom operating
    system without installing the matching *.calz file.
    OR
    you are attempting to load a non-EFILive custom operating
    system.
    Please save this calibration's *.ctz file
    and email a copy of it to: support@efilive.com
    so that we can add support for it.
    15878459 OS from an 09 LMM A50 controller says it is not supported in V7.5 build 275 for me. Should this be available?
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
  5. #35
    Bobo, this is listed as a known issue here with the fix.
    https://forum.efilive.com/showthread...e-and-firmware
  6. #36
    Nov 2005
    Sent the file to support. I see the CTZ file for the OS in C:\Program Files (x86)\EFILive\V7.5\Calibrations\A50
    Quote Originally Posted by bobo View Post
    OR
    OR
    system.
  7. #37
    Why? Did you follow my link?
  8. #38
    Nov 2005
    I did not see it....sorry about that....and thanks for the link!
  9. #39
    No worries, you may not have seen my link before reposting
  10. #40
    Nov 2012
    [QUOTE=GMPX;215490]All files read with EFILive are stored in our own .ctz format for a number of reasons, there is a lot more data saved in to the .ctz file other than the actual contents of the ECM.
    For sure.
    Which I would like to ask, is if I could modify a reading of these E80s, like I do in other programs (WinOls for example), in a hexdecimal table or 2D view. If this was possible, we would modify at least 10 vehicles now!
    Thank you for your patience, GMPX.
  1. Jan 17 RC2 Problems
    By ScarabEpic22 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2010, 11:57 AM
  2. BB Logging Update Jan 07, 2008
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: March 9th, 2008, 11:32 AM
  3. LB7 / LLY .cal file update - 08-Jan-2008
    By GMPX in forum General (Diesel)
    Last Post: January 13th, 2008, 09:56 AM
