Results 1 to 10 of 18
Thread: Known issues with Jan 2015 release of the EFILive software and firmware.
    Default Known issues with Jan 2015 release of the EFILive software and firmware.
    Currently known issues and possible workarounds for the Jan 2015 release of the EFILive V7.5.7.275, V8.2.2.269 software and the V2.07.76 FlashScan and AutoCal firmware.
    Note: Issues 2 thru 9 have been fixed. The fixed version is available here: https://forum.efilive.com/showthread...pdate-Feb-2051
    Issue 1:
    Workaround:
    None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    Issue 2:
    All A50 *.calz files are corrupt which means A50 tune files cannot be opened/edited using the V7.5 software.
    Workaround:
    Download the attached A50.zip file and unzip the three *.calz files into the folder: \Program Files (x86)\EFILive\V7.5\Calibrations\A50, overwrite the existing files. Will be fixed in the next update.
    Issue 3:
    In the V8 [F5: BBX]->[F6: Quick Setup] window, the name of the currently loaded quick setup file is not displayed above the list of quick setup files.
    Workaround:
    None. Will be fixed in the next update.
    Issue 4:
    For LML tune files, changing the VIN using the V7.5 software does not change the VIN displayed by the V8 software.
    Workaround:
    Change the VIN using the V8 software: [F3: Tune]->[F4: Properties]->[Controller Information] page, then click on the [...] button to the right of the VIN. Will be fixed in the next update.
    Issue 5:
    The timing calculator is not available on some Cummins fuel tables.
    Workaround:
    Issue 6:
    Updating FlashScan/AutoCal configuration files using the [Check Firmware] button on the main V8 window, then disconnecting and reconnecting FlashScan/AutoCal, some config files are reverting back to their old versions.
    Workaround:
    Perform the [Check Firmware]->[Update Files], then perform the following: [F5: BBX]->[F2: Scan]->[Read], then [Program Selections Only (faster)]. That will correctly flush the buffers. It will be fixed in the next update. Will be fixed in the next update.
    Issue 7:
    Black Box Logging does not log data for GM controllers.
    Workaround:
    None. Updated firmware will be posted ASAP.
    Issue 8:
    Wide band O2 serial interface data logging does not work.
    Workaround:
    Issue 9:
    Some E92 table axis are defined incorrectly
    Workaround:
    None.
    Lifetime Member izaks's Avatar
    Aug 2003
    Jan 2015 ?
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Member mpdtune's Avatar
    Jul 2013
    Timing calculator is missing for 07-09 6.7 Cummins on the main table. E2504 OS 11620807
    May 2010
    Tables B0169 and B0170 In E92 have wrong max value
    it should be 2 but the maximum is 0.02
    EFILive Tuner
    Oct 2006
    Any reason the release notes link ends up here?
    The Tremor at AIR
    Quote Originally Posted by 5.7ute View Post
    My really bad compueter skills. Fixed now.
    Quote Originally Posted by mpdtune View Post
    Working to fix this...
    Investigating...
    Quote Originally Posted by izaks View Post
    Jan 2015 ?
    I try to not appear stupid online but sometimes I can't help it.
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    Not really a bug, but when using the quick setup screen in V8 the software used to display the selected quick setup file name where I have in red in the screenshot. Now it does not, kind of nice to double check that the correct setup file is being loaded.Click image for larger version.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
  1. Known issues with Oct 28, 2014 release of the EFILive software and firmware.
    Last Post: January 27th, 2015, 07:42 PM
  2. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  3. Known issues with Jul 19, 2014 release of the EFILive software and firmware.
    Last Post: September 12th, 2014, 12:12 PM
  4. Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Last Post: July 10th, 2014, 10:12 AM
  5. Known issues with Jun 21, 2014 release of the EFILive software and firmware.
    Last Post: July 3rd, 2014, 11:12 AM
