Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Known issues with Jan 2015 release of the EFILive software and firmware.
    Sep 2003
    I can't change G0901 Fan Power from Metric to Imperial for E92 OS 12662762.
    Thanks.
    Quote Originally Posted by anarchydiesel View Post
    Not really a bug, but when using the quick setup screen in V8 the software used to display the selected quick setup file name where I have in red in the screenshot. Now it does not, kind of nice to double check that the correct setup file is being loaded.Attachment 17970
    Yes it is a bug, that field is being obscured by the top of the file list. Fixed in next update.
    Jan 2009
    Ive noticed that changing LML vins in V7.5 does not migrate over to V8. Truck doesnt seem to mind but its nice to keep track of what was previously open in the V8 window.
    Quote Originally Posted by Mitco39 View Post
    I'm investigating the problem.
    Meanwhile if you change the VIN using the V8 software the change will be visible in both the V7.5 and the V8 software. To change the VIN in the V8 software, use the [F3: Tune]->[F4: Properties]->[Controller Information] page. Click on the [...] button to the right of the VIN.
    Jan 2009
    Thanks Paul.
    Mitch
    May 2010
    I Noticed that In E92 OS 12663390
    the MIL is on and after checking the codes i find P2097 and P2099 while they are set to not reported and no MIL in the tune file so i dont know what is the problem is
    EFILive Tuner
    Nov 2005
    With V8 Scan and Tune open, and V2 connected, select the Check Firmware option, update firmware. Once on Jan 27 firmware select Update File to update config The config files appear to program and switch from x check boxes to tick check boxes.
    Disconnect FlashScan, close V8, reconnect and open V8, select firmware again and the config files revert to x check boxes requesting an update.
    Original post here https://forum.efilive.com/showthread...e-config-files
    Cindy
    Update available here:
    https://forum.efilive.com/showthread...pdate-Feb-2015
  1. Known issues with Oct 28, 2014 release of the EFILive software and firmware.
    Last Post: January 27th, 2015, 07:42 PM
  2. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  3. Known issues with Jul 19, 2014 release of the EFILive software and firmware.
    Last Post: September 12th, 2014, 12:12 PM
  4. Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Last Post: July 10th, 2014, 10:12 AM
  5. Known issues with Jun 21, 2014 release of the EFILive software and firmware.
    Last Post: July 3rd, 2014, 11:12 AM
