I can't change G0901 Fan Power from Metric to Imperial for E92 OS 12662762.
Thanks.
Thanks.
Ive noticed that changing LML vins in V7.5 does not migrate over to V8. Truck doesnt seem to mind but its nice to keep track of what was previously open in the V8 window.
I'm investigating the problem.
Meanwhile if you change the VIN using the V8 software the change will be visible in both the V7.5 and the V8 software. To change the VIN in the V8 software, use the [F3: Tune]->[F4: Properties]->[Controller Information] page. Click on the [...] button to the right of the VIN.
I Noticed that In E92 OS 12663390
the MIL is on and after checking the codes i find P2097 and P2099 while they are set to not reported and no MIL in the tune file so i dont know what is the problem is
EFILive Tuner
With V8 Scan and Tune open, and V2 connected, select the Check Firmware option, update firmware. Once on Jan 27 firmware select Update File to update config The config files appear to program and switch from x check boxes to tick check boxes.
Disconnect FlashScan, close V8, reconnect and open V8, select firmware again and the config files revert to x check boxes requesting an update.
Original post here https://forum.efilive.com/showthread...e-config-files
Cheers
Cindy
Update available here:
https://forum.efilive.com/showthread...pdate-Feb-2015
