View Poll Results: How would your rather view intake air flow when measured using imperial units?
Voters
19. You may not vote on this poll
  • Pounds per minute
    17 89.47%
  • Pounds per hour
    2 10.53%
Results 1 to 10 of 18
Thread: MAF lbs/min or lbs/hour?
    Default MAF lbs/min or lbs/hour?
    How would your rather view intake air flow when measured using imperial units? Pounds per hour or pounds per minute.
    (Metric units for air flow are measured grams per second.)
    EFILive originally displayed airflow in lbs/min. That was changed to lbs/hour to bring the absolute values (and hence the number of decimal places to be displayed) closer to the grams/second metric values.
    i.e. for most normally aspirated LS1 intake airflow:
    - grams per second range from 0 to 400
    - lbs/hour range from 0 to 4000
    - lbs/min range from 0 to 66
    both grams/sec and lbs/hour can be represented as whole numbers. lbs/min requires one or two decimal places.
    Nov 2003
    Blacky,
    I used lbs/min for years and know the numbers at different
    conditions off the top of my head - going to lbs/hour now requires
    dividing by 60. Flow of 2400 lbs/hour is 40lbs/min which is right around
    the top number I get with the stock MAF and stock MAF calibaration
    in the PCM (peak might be around 41 lbs/h).
    Gert
    Jan 2004
    I agree with 2000ssnb. It's just something I'm used to at this point.
    Whoever changed it should be fired. :lol: :wink:
    Quote Originally Posted by XLR8NSS
    Ok, I'm clearing out my desk now.... :cry: :cry: :cry:
    Guess I need to do some more canvasing of what people really want instead of what "works best on paper".
    Even with just a few votes cast, it looks like people want lbs/min.
    Jan 2004
    I'm going to give you a pardon but, just this once. :lol:
    Honestly, I'm not sure if it really matters what units the MAF Pid has for anything important. It's just something we're used to from previous versions of your fine product.
    Jul 2004
    Don't get mad at Paul, get mad at me. I'm the one who pointed out that lb/hour was the more commonly used measurement and ultimately caused the change.
    Sorry, but it really is a more common measurement.
    Ira
    Causer of trouble
    Jul 2004
    On second thought, I wonder if you should leave it the way it is and add a calc PID of lb/hr/60 to satisfy those who want it the old way.
    Ira
    Jan 2004
    Quote Originally Posted by Ira
    Ira
    Causer of trouble
    Nah, not mad at anyone. Just trying to understand why the units were changed and see if they could be changed back.
    I don't agree that lbs/hr is a more common measurement for MAF airflow, at least not in the automotive field. I don't know if I've ever seen those units used for MAF airflow actually. Can you give examples for my own curiosity of where lbs/hr is used?
    I know turbo maps give airflow in lb/min. Just about every reference I've ever seen on MAF airflow is either in g/s or lb/min.
    The most common use of lb/hr units is for fuel flow from what I've experienced.
    Maybe the people who want lbs/hr could make a calculated pid.
    Jun 2004
    Ahhhhhh!!!!! Pounds per minute please!
    I've been all over every setting in the V7 software recently trying to figure out why the imperial is set to pounds/hr and looking for the switch to set it back to pounds/minute. The hour value is so foriegn to me that I've set it to grams/sec just so I'm not thinking "divide that by 60" every time I see the number.
    After using V5 and V6 for a while now, I'm really very accustomed to the per minute setting. I agree with the above post, instead of making the standard PID change from minute to hour, there should be an added calculated PID for those who want to see it in pounds/hr.
    Richard -
    2008 Trailblazer SS - TVS1900
    Senior Member AllCammedUp's Avatar
    Jun 2003
    I'm going to have to vote for lb/min, as well. I'm more accustomed to it, and I like the idea of the inlcluded calculated PID to get the lb/hr value if we want or need it. Please change it back.
    Whitney Roberts
  1. EFILive on Eleventh Hour tonight?
    By C.C.Reed in forum Lounge
    Last Post: September 10th, 2009, 10:56 AM
