View Poll Results: How would your rather view intake air flow when measured using imperial units?
Voters
19. You may not vote on this poll
  • Pounds per minute
    17 89.47%
  • Pounds per hour
    2 10.53%
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: MAF lbs/min or lbs/hour?
  1. #11
    Oct 2003
    I always use g/sec - but lb/min seems more sensible. Smaller numbers :wink:
    joel
  2. #12
    Lifetime Member jfpilla's Avatar
    lbs/min x 10 at peak = HP(roughly).
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  3. #13
    Sep 2003
    I usualy think in terms of lbs/min. but it doesn't really matter to me.
    I'm old and Retired! I used to go fast. I don't go so fast anymore ...but, my cars still do!
  4. #14
    Maybe there can be PIDs for each of them...
  5. #15
    Jan 2004
    or an option to choose what imperial unit to use?
  6. #16
    The V7.1.9 Scan Tool will be changed back to lbs/min.
    A calculated PID of MAF lbs/hour will also be provided as:
    CALC.MAF.lbph = {SAE.MAF.lbpm}*60
    It may not be the "correct" way to repesent air flow but it is the most popular way.
    Sep 2003
    8) Works for me.
    Thank you.
  8. #18
    Jan 2004
    Paul - You're Ok in my book, no matter what those other guys say about ya. :lol: :wink:
    Thanks for the revision.
  1. EFILive on Eleventh Hour tonight?
    By C.C.Reed in forum Lounge
    Last Post: September 10th, 2009, 10:56 AM
