Results 1 to 2 of 2
Thread: can i use pico style injectors on 98 l31 vortech computer?
    May 2011
    Default can i use pico style injectors on 98 l31 vortech computer?
    as the title states i am wanting to control injectors with the l31 computer. i am converting over to an edelbrock pro flow intake and dont have the money yet for the 411 pcm conversion and am just wanting to run the stock computer for now.
    Jul 2005
    So long as the Edelbrock Pico Injectors are high impedance, they can be controlled with the Vortec "blackbox" PCM's.
    I just checked and the Edelbrock Pico injectors OHM at 14.9, so they are indeed a "saturated" high impedance injector, and not a "Peak and Hold" low impedance injector.
    Stock Vortec 305/350 poppets flow at 24.1 lb/hr @ 63 psi.
    At the very least you will have to adjust the IFR(injector Flow Rating) in the calibration to tune for whatever sized Pico injector size you use, and the exact fuel pressure you will run it at.
    peace
    Hog
  1. 4.8 vortech
    By big block 88 in forum Gen III V8 Specific
    Last Post: September 15th, 2010, 08:45 AM
  2. EV6/LS2 Injectors in 98 L31 Vortec
    By onegonewild in forum Gen III V8 Specific
    Last Post: March 20th, 2010, 08:44 AM
  3. 04 Corvette computer locked need to reflash whole computer
    By Precisionauto in forum Gen III V8 Specific
    Last Post: October 8th, 2007, 11:42 AM
  4. VSS Signal style/type ? (pickup question)
    By J 98ta in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 03:40 PM
