Results 1 to 9 of 9
Thread: ol maf tune or ve maf open loop and lambda question
    May 2012
    Default ol maf tune or ve maf open loop and lambda question
    Hi everyone. Im in the process of tuning an ls6 that is on a xj cherokee. Im on the maf tune. Runing a open loop maf. Tuning it on the street. On part throttle and idle and cruise. Where 14.68 is commanded. Is acceptable .99 lambda??? With engine temp it changues a litle but most of the time is .99- 1 lambda.. can i stay on maf only or is better to tune the ve too and run a ve maf open loop. This car is for offroad. Doesnt have 02s
    Lifetime Member limited cv8r's Avatar
    May 2005
    A benefit of tuning the VE would be in case of a maf failure for some reason, you would then know that your fueling is still safe.
    May 2012
    You are correct, i think the lm1 stoich is 14.7 and thr stoich in my tune is 14.68. Should i changue the 14.7 to 14.68 using lm software
    Can you tune using Lambda (from the LM-1)...?
    ( it is simpler, the MAF and/or VE correction factor is {GM.EQUIVRATIO} * {EXT.WO2LAM1} regardless of stoich AFR )
    ( of course, you set B3601 to the stoich AFR of the fuel you are running )
    +1 I would do both MAF and VE.
    May 2005
    Depending on your OS you may also have something like "{B0120} RPM Threshold For Airflow Calculation"
    May 2012
    That was exactly the answer i was looking for,,, I did tune it with lambda, using the lm1 with serial connection, but i was unsure if the value programed for stoich in the lm1 changues the lambda output... it looks like it doesnt then, i leave it like that..
    the other question:: What is an acceptable BEN??
    By using Lambda and/or EQR (which is 1/Lambda) you can simply ignore AFR...
    ( you simply set the stoich AFR in the tune file (e.g. table B3601 for LS1B) and then ignore commanded AFR and ignore wideband AFR ).
    Acceptable BEN is 1.00 +/- 0.03
    See the calc_pids.txt file in the post #1 of the Calc.VET thread
    May 2012
    Thank you. Im already using that calc pid and already tuning with EQR and lambda and using commanded AFR pid and Wide Band AFR pid just to see it because im used to see AFR. Thank you again, i understand now
  1. 2012 CTSV Maf scaling, open loop issues.
    By ditosmotors in forum E37, E38 & E67 PFI ECM's
    Last Post: June 27th, 2012, 02:37 PM
  2. MAF Open Loop
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: January 4th, 2007, 12:43 PM
  3. Today I tested the difference between SD and MAF mode both in open loop
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2006, 01:36 AM
  4. Open Loop with Electronic Throttle and IAT in MAF
    By deezel in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2005, 06:10 PM
  5. Procedure for turning off MAF and forcing open loop for SD?
    By AllCammedUp in forum General (Petrol, Gas, Ethanol)
    Last Post: May 4th, 2005, 12:10 AM
