Results 1 to 2 of 2
Thread: 2003 silverado 8.1 w/5 speed allison and whipple intercooled supercharger
    Senior Member djv86's Avatar
    Nov 2014
    Default 2003 silverado 8.1 w/5 speed allison and whipple intercooled supercharger
    a customer brought his truck into the shop with a detonation issue.. whatever tuning has been done to the engine and or the incorrect spark plugs have managed to blow up 3 engines the past 7 months.. engine is bone stock minus the carb approved whipple supercharger kit including the intercooler.. engine did have the incorrect heat range spark plugs.. correct plugs are in now and test drive will be tomorrow. I'm here to ask if anybody has performed a speed density tune on one of these engines..
    I've got a few different methods of tuning and here to see what anybody here has done or found best results. i under stand the whipple ecu adds extra fuel once boost kicks in the only problem is the gm ecu NEVER goes into open loop and takes fuel away from the stock injectors under boost to maintain 14.7 afr causing horrible knock and piston damage.
    is it possible to make a custom map using the CALC.VE method and during the copy and pasting to buy the new map the original map only goes up to 105kpa and this engine under boost makes almost 150kpa can i just increase the map reading to 160 and put a boost sensitive map sensor in or is the custom OS a MUST for controlling boost.. only thinking this since the moment i create the custom os is changes the os part number and here in california I'm unaware upon if the new smog machine will catch the diff os part number.
    steps I've done so far
    1. fuel pressure does what its supposed to per. whipple
    2.boost doesnt excess whipples spec
    3.monitored AFR using my wideband on bank 2 sensor 1 location and the AFR is between 10-11.1 under WOT and still "pings" while at WOT watching knock retard on the TECH2 it only see a maximum of 4 degrees retard
    any help or information would be amazing.
    hopefully there isn't already a thread on this exact configuration.
    in the attachment is the current tune file before any custom stuff have been done minus tire and fuel tank parameters
    Nov 2014
    whoops sorry noticed its in the wrong area please delete if needed moderators..
  1. 2000 L29 454 Whipple Supercharger Tune
    By atlk2500 in forum Vortec V6/V8 Specific
    Last Post: March 30th, 2016, 07:36 PM
  2. Transmission tune for 2003 Silverado??
    By nfs13b in forum Vortec V6/V8 Specific
    Last Post: July 21st, 2014, 06:03 AM
  3. Silverado 2003 + PCM DBW Ground ?
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: May 7th, 2010, 05:38 AM
  4. 2001 Silverado 4x4 LM7 Vortec with Whipple & 42lb injectors
    By bratch in forum Vortec V6/V8 Specific
    Last Post: April 1st, 2007, 05:28 PM
  5. 2003 Silverado OS upgrade
    By John in forum General (Petrol, Gas, Ethanol)
    Last Post: October 3rd, 2005, 02:59 PM
