Results 1 to 10 of 12
Thread: Cummins swap question.
    Oct 2014
    Default Cummins swap question.
    I dont know if this is the right place to post this on here. But I have an 07 5.9 Common Rail I want to put in my 03 1500 Z71. I know crazy right and why do it? Its a project and i want to see if i can do it. I think it would be awesome for somebody to roll up beside me and have to take a double take when they hear that Cummins in a 1500 chevy lol. I was gonna ask if anybody knows where to get a wiring harness for this conversion or knows somebody that makes a wiring harness for it. Sorry if this is not the right place to post this. I saw the gasser forum had an option for conversions but figured some of you cummins mad scientists on here may know where I may find a harness
    Senior Member tylerltr450's Avatar
    Aug 2014
    I would assume you would need all the ecm wiring and trans wiring if keeping an auto and nothing doing a manual valve body.
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
    Oct 2014
    I wanted to put a 6speed behind it. I've got another motor in the works that I am fixin to rebuild. Got a complete wiring harness for it and ECM. I just need to find someone that can make a harness for the conversion.
    07 5.9 4x4, Fully Built SunCoast, II 64/80 Silver Bullet, ARPs, Snow Perf Water/Meth Inj., Fass 150 Titanium, K&N Intake, BD Elbow, CC Tunnel Ram, Own & Others Efi Live Tuning w/CSP5, Glow Shift Max Tow Gauges, 4" Turbo back w/ Axle Dump, 35's, and good Ol Ranch Hands.
    Under Construction:
    2003 Chevy 1500 Z71, w/P-Pumped 5.9 Common Rail, NV4500, South Bend DD, 200Hp Inj.........currently saving greenbacks for more parts.
    Aug 2014
    well im assuming its all 06 -07 ecm and motor?
    Oct 2014
    Yep my original 07 that I melted #6 in.
    Under Construction:
    Aug 2014
    here is a wiring diagram. Use in Internet Explore or Opera. If you cant get it to work I can send you a link to my google docs where I have most of it in PDF form.
    http://www.rambodybuilder.com/2006/dr/drmo.pdf
    Oct 2014
    I'm workin on my other cummins right now and not able to use a cpu right now. Is this for the cummins harness or to convert it to Chevy? I really appreciate the help man.
    Under Construction:
    Aug 2014
    Its everything for an 06 07 cummins harness. It shows all you could want for wiring where splices are and what they are and all the different pin connectors its a very useful website. I used this on my auto to nv5600 swap helped out more then you ever would know.
    Oct 2014
    I certainly appreciate it!
    Under Construction:
    Nov 2005
    Do you want to keep factory gauges, AC, and everything else working? Do you have heated seats and all that stuff?
    12.9s @ 108 mph
    many thanks to Ross and Paul
  1. Cummins 5.9L Tuning Question
    By WisconsinHick1 in forum Cummins 5.9L
    Last Post: January 22nd, 2014, 11:53 AM
  2. segment swap question
    By aaronr in forum General (Petrol, Gas, Ethanol)
    Last Post: May 10th, 2012, 05:59 PM
  3. 6.7L Cummins swap/transplant
    By wilintolern in forum Cummins 6.7L
    Last Post: November 28th, 2011, 03:40 PM
  4. 98 pcm swap question
    By rpmauto in forum Gen III V8 Specific
    Last Post: March 21st, 2011, 04:34 AM
