Results 1 to 10 of 10
Thread: e67 maf will not fail for sd
    Apr 2006
    Default e67 maf will not fail for sd
    e67 gmpp controller will not fail maf for sd what am i missing car fires then dies immediatly no maf codes
    E67 read_0005.ctz
    Try setting C0301 to zero.
    Do you have a log showing ETCTP, RPM and MAF g/s...?
    Apr 2006
    here is the log
    Aug 2010
    Try this one ...
    Apr 2006
    still no fail, no codes set
    Aug 2010
    Try this one ... if it still does not fail the MAF and default to SD mode, then remove the "Yellow" signal wire from the MAF connector.
    Apr 2006
    the maf is removed its a harrop itb setup there is a iat sensor wired in
    Apr 2006
    worked
    thanks a bunch!!
    Aug 2010
    No worries ... glad it worked out ... had forgotten that High Speed Airmass Mode was originally set to well below idle RPM on some of the older GMPP controllers.
  1. MAF wont fail for VVE tuning
    By 2007chevy5.3l in forum E37, E38 & E67 PFI ECM's
    Last Post: July 25th, 2013, 07:20 AM
  2. EFI fail to load
    By kenny in forum Duramax LLY
    Last Post: June 19th, 2011, 11:20 AM
  3. If you fail to plan, you plan to fail!!
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2009, 07:02 AM
  4. Which maf fail numbers are you using for C2907 and C2908?
    By onfire in forum Custom Operating Systems
    Last Post: August 30th, 2007, 08:19 AM
  5. I cant get the"MAF freq Fail 1"parameter to = 0
    By SmaknSS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 2nd, 2005, 05:29 AM
