But was it for a 4L80E...?
( I have a link to one somewhere here )
Yes 2002 6.0l with 4l80e
05 lly 11.69 @ 115mph. stock motor, s475, 40% nozzles, lbz reg
685hp/1100ftlb
11 Cruze 1.4L turbo
Was it intended for use with a 4L80 tune ? Or did it include a relay (intended for use with a 4L60 tune) ?
Simply copying the parameters from a 4L80 tune into a 4L60 tune won't make the tune compatible with a 4L80 ... the solenoid logic and TCC function are different. This requires an actual 4L80 tune, or a transmission segment swap into your current tune.
I also have the pcm from the 02 truck that this trans came out of. Could I just switch the pcm and vin number in the truck?
685hp/1100ftlb
11 Cruze 1.4L turbo
I'm to the point now. I will pay someone to do the segment swap for me because I have to get my brothers truck back up and running. His other truck broke also. So he has nothing to drive.
685hp/1100ftlb
11 Cruze 1.4L turbo
When you do the segment swap you also have to repin a few wires... you need to check how the harness is pinned.
These are some of the difficulties that can be encountered when people fail to do sufficient research and planning prior to going ahead with conversion projects.
By your description, it would appear that the adapter harness you purchased was intended for use with a 4L80 calibration.
You attached your original tune in post #1 of this thread.
Attached below is this same tune, but with 4L80 segments inserted.
Hopefully this will get you (and your brother) going again.
I tried everything that you all suggested and had no luck. I have not tried your tune Taz. I ended up swapping in a pcm out of a 6.0/4l80e truck. And it shifts perfect. I know I said the truck is a 99 but I'm wondering if it has a 98 pcm. What I have read was the 98s are not compatible with a 4l80e. And I would have had more time to research this project but the pump went out of his dodge so we tried to get his chevy back up and running.
Thanks for all the help
Taz I will put the other pcm out and see if your tune works. And report back. Once again thank you
685hp/1100ftlb
11 Cruze 1.4L turbo
