Currently known issues and possible workarounds for the Feb 09, 2015 release of the EFILive Software and Firmware
- Software: V7.5.7.277
- Software: V8.2.2.271
- FlashScan/AutoCal firmware: V2.07.78
Issue 1:
Workaround:
None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
Files that are to be copied to FlashScan or AutoCal may not contain commas in their names.
Workaround:
Remove all commas from filenames prior to attempting to copy them to FlashScan or AutoCal. Will be fixed in the next update.
Issue 3:
Images are too large on the folder buttons in the [F8: Tools]->[F2: Search]->[Browse] tab page. That also causes the text on some buttons to wrap incorrectly.
Workaround:
None - it is a visual problem only and does not affect the operation of the software. Will be fixed in the next update.
Issue 4:
Saving Cummins CMD/CME tune files using the V7 software removes the VIN from the file and reverts it to "N/A".
Workaround:
After saving the file using V7, open the file in V8 and change the VIN back to its correct value on the [F3 Tune]->[F4: Properties]->[Controller Information] tab page. Will be fixed in the next update.
Issue 5:
Logging scan tool data using V7 pass-thru when the PID selection includes calculated PIDs will cause log file data corruption.
Workaround:
Exit from all EFILive software.
Download the attached obdiiV7.zip file and unzip it into the folder C:\Program Files (x86)\EFILive\V7.5 (overwrite the existing obdiiV7.dll file).
You will need administrator privileges to overwrite the obdiiV7.dll file in that folder.
