Results 1 to 6 of 6
Thread: Curious about VVT tables in this C7Z06 file
    Feb 2015
    Default Curious about VVT tables in this C7Z06 file
    I've had to tune this car with HP but since the release of support for the new OS I have been able to look into tuning this with EFILive. I always poke through tables before making changes and I've noticed the VVT stuff maybe in the wrong order. Specifically, the High Baro VVT Inlet table is most likely stuffed into the exhaust Mid Baro table.
    Also, all the VVT numbers seem to be off by a factor of 4 (or 8 if you wanted these numbers in crank degrees). I've noticed this in other files as well.
    Let me know if I'm crazy?
    -Seth
    Seth, thanks for the review, I'll pass it on to Paul.
    Hi Seth,
    There has been an E92 calibration update in the latest pre-release here:
    https://forum.efilive.com/showthread...te-Feb-14-2015
    Please let me know if the tables in question are now correct or if they still need fixing.
    Feb 2015
    Sorry Paul,
    Been a little busy but just to update you:
    Tables still look the same to me after redownloading and installing the new software versions. Medium and Low Baro exhaust cam tables have values in them (High table is empty) while appearing to hold values you would think to see in the intake cam side of the software. The intake side still looks a bit awkward almost like some kind of an AFM mode table ? Would there be any logic to use the exhaust tables for any reason?
    -Seth
    Hi Seth,
    You are correct, the scaling is defined incorrectly on those tables, they also changed things a bit from what we expected as far as the table order in the bin files, best leave them alone for now while we fix them all up.
    Feb 2015
    Good to know guys!
    Cheers!
    -Seth
  1. Can VVT be enabled on a non VVT tune? E67 2007 CTSV
    By 04colyZQ8 in forum Gen IV V8 Specific
    Last Post: April 2nd, 2017, 05:57 PM
  2. E78 VVT Tables
    By a78turbo in forum E78, E83, E84 PFI ECM's
    Last Post: July 19th, 2016, 09:05 AM
  3. Any body have stock 2015 C7Z06 ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: February 17th, 2015, 09:33 AM
  4. Curious about Allison 6 speed solenoid logging
    By Brian1 in forum Black Box Logging
    Last Post: October 20th, 2009, 01:15 PM
