Results 1 to 10 of 10
Thread: Excessive timing retard on full throttle down shift
    Feb 2005
    Default Excessive timing retard on full throttle down shift
    Hey all, how can we soften the timing retard on full throttle downshift without adjusting minimum timing?
    this only seems to happen when in top gear, plant your foot, the car hits a brick wall downshifts then comes alive.!!
    Nov 2012
    I have the same problem.
    I started looking at T43 now, and after I m going to do tests.
    Nov 2012
    Problems...
    Without any modification in T43, just speedometer and rpm limiter, this problem remains!
    Is engine exceeding any engine sanity table...?
    Post files.
    Aug 2009
    torque management strategy , did you screw with the torque tables ??
    Feb 2005
    I did modify the torque tables, with or without modification it still retards.
    Aug 2009
    Quote Originally Posted by AGRO View Post
    Have a play with these Click image for larger version.
    Senior Member auspeed's Avatar
    Jul 2010
    I found by disabling the Torque Management on upshift.... made the transmission perform poorly, however I'm curious to know how you control how much spark is retarded on the upshift??
    Feb 2005
    Any movement on this?
    Aug 2018
    I wouldn’t fully shut off the TQ management. Just reduce it.
    Tuning the trans shift behavior is in the ECU
    Post up your file. You probably have some nannies still turned on in the ECU.
  1. need to retard timing under boost
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 8th, 2008, 02:07 AM
  2. Timing retard
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2008, 10:25 PM
  3. Knock Retard On Throttle Close
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: February 13th, 2008, 08:44 PM
  4. Nitrous timing retard
    By PRAY in forum Gen III V8 Specific
    Last Post: December 12th, 2007, 06:49 AM
  5. Light Throttle Knock Retard
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2005, 06:37 AM
