Results 1 to 10 of 16
Thread: 2011 lml OS6249 delete issues
    Jan 2015
    Unhappy 2011 lml OS6249 delete issues
    Ive been trying to delete 2011 lml OS 6249. I noticed on two 2011 trucks that they dont have the DEF level speed limiter switch like the 5750 that i found on the 2013 and 2014. Well I turn some switches off, tried three different combos, all three had a dead pedal. has anyone dealt with this before that would like to share how they got it to work?
    thanks
    08 LMM CC Dually
    Canada
    Jan 2015
    Got it. Thanks guys...
    08 LMM CC Dually
    Canada
    Jan 2007
    care to share what you did to get it working, I have same issue
    Jan 2015
    I emailed you some info
    08 LMM CC Dually
    Canada
    Jan 2015
    I'm having the same grief tried several combos and still have a dead pedal 11 lml also a 6249 OS any help would be greatly appreciated
    Jan 2015
    Quote Originally Posted by DETROIT2STROKE View Post
    Email sent.. did it fix the dead pedal for you?
    08 LMM CC Dually
    Canada
    Dec 2015
    Quote Originally Posted by LMMPerrona View Post
    thanks
    Would you mind sharing how you fixed this? I see that you figured it out, but you just PM'd the individuals.
    Thanks.
    Last edited by racintj; December 9th, 2015 at 11:12 AM. Reason: Forgot to add the original quote.
    Apr 2006
    Anyone have any updates on this? I've been fighting this OS for two weeks, can't get rid of the dead pedal. Seem to be missing something I haven't had problems with in the other LMLs.
    thanks!!
    Jan 2015
    Lmm perona has it figured if he dont chime in ill help yeah out
    Lifetime Member Road's Avatar
    Feb 2015
    Quote Originally Posted by Tarmacblack View Post
    thanks!!
    Are you making any changes to the speed limiter parameters? If so leave all limiters stock and make sure you have the correct OS.
  1. lml delete
    By akaponch in forum Duramax 2011+ LML / LGH
    Last Post: June 30th, 2017, 06:10 AM
  2. 2011 LML Duramax Tuning Please.
    By duramaximizer in forum Diesel
    Last Post: April 28th, 2011, 10:18 AM
  3. Info on New LML engines for 2011
    By Redline Motorsports in forum Duramax 2011+ LML / LGH
    Last Post: April 8th, 2011, 02:02 PM
