Results 1 to 3 of 3
Thread: delete corvette LS1 DBW
    Feb 2015
    Default delete corvette LS1 DBW
    can anyone point me in the right direction to delete the DBW on a 2002 corvette and go to DBC
    this is for a full blown road race car that continually has problems with TAC module and TPS correlations using aftermarket 102mm TB
    Can I run the car with a 2002 Camaro PCM and just copy and paste my current tables over with EFIlive?
    can I use existing wiring to the TB and just change what the wires do, like run IAC and throttle position?
    I understand the basics, and have repined the computers before so I have a minimal understanding.
    I also know a little about EFI live as I do my own tuning, but it is very rudimentary. The car is tuned speed density, no MAF, no knock, no O2's
    any help would be appreciated!
    Jan 2006
    Are you still running a BCM, stock cluster or anything other factory electronics? It would be way easier IMO just to correct the issues with the tps, tac module and TB than going over to a cable.
    Feb 2015
    yes I am still using a few gauges in the stock cluster, so I assume that the BCM is still running those.
    mainly I still use the DIC so I can clear codes.
    there is no abs system in the car.
    I believe that the TAC module and pedal are ok and that its an issue with the aftermarket throttle body.
    I have the same issue on 2 cars, and when I change the throttle body it goes away for a while.
    Heck, it may be an issue with my tune but I don't know enough about it.
    if I remember correctly the code is P1516 and it goes into reduced engine power.
  1. E38 Corvette DBW Tuning Questions
    By gpr in forum E37, E38 & E67 PFI ECM's
    Last Post: March 24th, 2014, 10:48 AM
  2. Corvette C4, LS1 P1SC Procharger need tune
    By legendvette in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 8th, 2010, 04:04 PM
  3. Running rich ls1 corvette 402 stroker
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 6th, 2008, 04:03 PM
  4. 1998 Corvette LS1 VATS problem
    By Rewire in forum Gen III V8 Specific
    Last Post: September 12th, 2007, 10:36 PM
