Results 1 to 10 of 13
Thread: Update: Mar 03, 2015
    Default Update: Mar 03, 2015
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Notes:
    Known Issues:
    Check for known issues here.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 279
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 273
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.80 (Mar 03, 2015
    To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Senior Member DieselMafialb7's Avatar
    May 2012
    ● Attempting to open Cummins CMD/CME CSP5 tune files or Cummins CMD/CME log files was failing with various errors.
    already working on csp for 10-15? or is this a mistake I just downloaded this update and didn't see the upgrade there
    We are working on them, but that was a typo
    May 2012
    why you gotta do that to me
    Jan 2009
    With this new update do we have to remake our scripts to handle multiple DTC instances? Or will the software adjust accordingly?
    This is going to save me sooooo much time!
    Apr 2006
    You have to redo the scripts. Yes, nice that 7 years of manually adjusting is over.
    Nov 2005
    Quote Originally Posted by Mitco39 View Post
    It's been in the documented release notes since mid-December, and was then reworked in January to make the interface more user friendly. We just featured it in the newsletter because we most people don't read the release notes. The reference to the March release, was to encourage users to update for support purposes. As Rob said, scripts need to be updated.
    Cindy
    Member pkincy's Avatar
    Sep 2003
    The download pages do not seem to be working.
    The download goes to http://download.efilive.com/Software....279_Setup.exe
    But a message says this webpage is not working.
    Same for V8
    Further details:
    The server at download.efilive.com can't be found, because the DNS lookup failed. DNS is the network service that translates a website's name to its Internet address. This error is most often caused by having no connection to the Internet or a misconfigured network. It can also be caused by an unresponsive DNS server or a firewall preventing Google Chrome from accessing the network.
    I do, however, have good internet service.
    I will try it from IE.
    Doesn't work with IE either.
    Perry
    1993 Corvette 40th Anniversary Roadster, 383, ZF6, Fikse's
    1993 Camaro 383, A4
    2008 C6 Z06
    2000 Silverado Pickemup
    1998 Camaro 1LE with LS2 402 is sold
    pkincy- I had an issue with a customer not being able to update to the feb 14th release. Had to clear his history and cookies and then it went through. I just downloaded the 03/03 update again to check and both v7.5 and v8 worked on my end..
    DraconianDiesel
    Dodge/Ford/GM Tuning
    2003 LB7 , 2006 LBZ
    2008 6.7 Cummins
    2008 6.4 Ford
    Sep 2003
    I will give it a try.
    Cleared it all. Server must be down. Won't work with IE, Firefox or Chrome yet all else works including the forum.
    Perry
    1993 Camaro 383, A4
    2008 C6 Z06
  1. Known issues with Mar 03, 2015 release of the EFILive software and firmware.
    Last Post: March 20th, 2015, 10:55 AM
  2. Update: Feb 14, 2015
    Last Post: March 3rd, 2015, 03:04 PM
  3. Update: Feb 2015
    Last Post: February 21st, 2015, 09:59 AM
  4. Update: Feb 09, 2015
    Last Post: February 10th, 2015, 06:29 AM
  5. Update: Jan 2015
    Last Post: February 4th, 2015, 06:55 PM
