Results 1 to 10 of 17
Thread: Update: Feb 14, 2015
    Default Update: Feb 14, 2015
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Notes:
    Known Issues:
    Check for known issues here.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 278
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 272
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Firmware, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.79 (Feb 14, 2015
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Dec 2006
    Thank you installed and testing
    2007 LBZ 2011 LML Silverado Pickups
    2015 GMC Denali 3500 Dually Diesel Pickup
    2007 Dodge 6.7 Pickup
    Feb 2015
    The most recent issue I have encountered after updating to this version is when opening EFI live v7.5 Scan tool the following error occurs.
    Error report generated by EFILive at 19:52:29 on Feb 15, 2015
    Error code: ERR_CONFIG/92
    C:\Program Files (x86)\EFILive\V7.5\Configuration\cummins_enhanced. prn(919): Slot UNM-08-5002 with units Amps not found. .
    EFILive Version: 7.5.7 (Build 278)
    Quote Originally Posted by 2013_Cummins View Post
    It is a bug in the V7 PID configuration for CMD/CME controllers. I'll post an updated cummins_enahnced.prn file. Look in the "known issues" thread for the update in a few minutes.
    Feb 2015
    Thanks Paul. Much appreciated.
    Feb 2015
    I still recieve the following error if I select the CME2350B controller and then close and try to re-open v7.5 Scan Tool
    Error report generated by EFILive at 20:36:27 on Feb 15, 2015
    C:\Program Files (x86)\EFILive\V7.5\Configuration\cummins_enhanced. prn(968): Units may not be specified for slot: SED-08-5010. .
    Aug 2014
    I don't know if this is an issue with the current release or something that has never been noticed or it is on my end which is entirely possible. Anyway with CSP5 on a 07 6.7 Cummins I noticed that pilot injection timing isn't switching when toggling between CSP5 positions.
    I have brought it up in the data log and confirmed it definitely not working It seems to be stuck on possibly "air density table adjust 3 to 5" in the internal flash rather than the CSP tunes.
    Any thought's on this, everything else is working perfect and as expected.
    Sorry for the delay, I did not see your post until now.
    The zip file in the known issues thread was updated about 4-5 hours after the initial update to fix known issue 3 - which also caused the problem you have reported.
    Please download the zip file and unzip it into the correct folder again.
    Quote Originally Posted by BigCE View Post
    When logging what is the PID 'AIRDENSC' "Air Density Table Scaler" showing?
    I noticed some weird VIN issue's in the tuning tool for LML the vins no longer match the old files and the one listed in the tuning file is not being programmed into the ecm.
    04 LB7
    2010 LMM
    2015 LML
  1. Known issues with Feb 14, 2015 release of the EFILive software and firmware.
    Last Post: March 3rd, 2015, 03:03 PM
  2. Update: Feb 2015
    Last Post: February 21st, 2015, 09:59 AM
  3. Known issues with Feb 09, 2015 release of the EFILive software and firmware.
    Last Post: February 12th, 2015, 08:04 AM
  4. Update: Feb 09, 2015
    Last Post: February 10th, 2015, 06:29 AM
  5. Known issues with Feb 2015 release of the EFILive software and firmware.
    Last Post: February 9th, 2015, 11:53 AM
