Results 1 to 3 of 3
Thread: Looking for CAX for B1859 (Closed Throttle Torque)
    Default Looking for CAX for B1859 (Closed Throttle Torque)
    I know this is in a 2006 cal we have but looking to get it for a 2007 Z06 we have here....does anyone have a CAX file for that year OS?
    HT
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Aug 2010
    Hello Howard,
    Given that this is a 2007 Corvette, I will assume that you are working with OS12611833 or OS12614676.
    I believe that you use multiple tuning softwares to provide the quality of tuning solutions that your company is known for. Why not simply adjust this parameter using HPT ?
    HPT was a couple of OS where the start point of this table is incorrect, and the table is populated with incorrect data (little more than electronic gibberish) - but both of the above mentioned OS are correct in HPT.
    If for whatever reason, you need this completed using EFILive, I don't mind configuring the Closed Throttle Torque table for you. The 2007 Closed Throttle Torque table is very different from the earlier 2006 variant.
    I can't give away corporate R&D (I have hundreds of CAX files), but I try to collaborate with EFILive users at no cost (whenever possible) to assist with tuning solutions.
    Just let me know if you still require assistance adjusting this table using EFILive - and I could configure the table to your specifications.
    Taz
    May 2010
    Sorry to ask but for what this table is used to ?
    EFILive Tuner
  1. Runaway throttle and throttle sticking, what tables can affect this?
    By RD in SD in forum E37, E38 & E67 PFI ECM's
    Last Post: May 11th, 2013, 02:20 PM
  2. Replies: 5
    Last Post: April 16th, 2013, 06:38 AM
  3. Trans hits 4th hard with light/no throttle, fine with moderate throttle
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 4th, 2013, 12:10 PM
  4. B5916 base spark closed throttle threshold vs. tps voltage
    By relentless addiction in forum Gen III V8 Specific
    Last Post: September 5th, 2012, 12:52 PM
  5. Torque management, TCS, TCS fast torque loss
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 05:16 AM
