Results 1 to 7 of 7
Thread: v2 bricked
    Feb 2015
    Default v2 bricked
    i was updating my firmware when my computer shut down now my v2 is a blank blue screen and no lights on it what can i do to fix this?
    Nov 2005
    When FlashScan is in dead poll mode the two orange LEDs will flash alternately. Can you please confirm if you are in this mode, or if there is no lights on at all?
    Out of interest, what version were you upgrading from and what version were you going to?
    Cheers
    Cindy
    Feb 2015
    No lights at all on the v2 just blank blue screen and I'll have to look at the one I was trying to update to
    Nov 2013
    Subscribed, and do not want to have this issue. Allout diesel, what firmware/bootblock did you have? I believe I have to update incrementally.
    Feb 2015
    I was running the same as the link you sent then it said it needed updated so when I was updating my computer shut down now when I plug the v2 in it doesn't respond at all Iv tried every way to get it to update but it will not connect I even tried a computer that has ever had efi on it and it still will not connect I can see where the computer is sending information to the v2 but the v2 is not sending anything back
    Hold down the V2's Ctrl key as you plug it into your PC (via USB port)...
    this boots V2 into dead poll mode (amber LEDs flashing in alternation), you can now program firmware into it (using EFILive Explorer).
    Feb 2015
    Wow is worked perfectly thank you so much
  1. Bricked my ecm?
    By VHR in forum Gen III V8 Specific
    Last Post: September 2nd, 2014, 06:17 PM
  2. I think I bricked Flashscan v2
    By Always2Slow in forum General
    Last Post: September 1st, 2013, 03:06 AM
  3. Bricked The V2??
    By RobsDmax in forum FlashScan V2
    Last Post: July 24th, 2013, 09:53 AM
  4. Bricked H3... almost
    By SwedeBurb in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 13th, 2012, 10:33 AM
  5. Fixing your Bricked V2
    By Ira in forum FlashScan V2 BB Logging
    Last Post: April 18th, 2008, 09:21 AM
