Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: how do i build a histogram in efilive ?
  1. #11
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    i have a V2 with a techedge 2 wideband , yes i can post a page shot ( i think )
  2. #12
    Aug 2008
    got to here in 5.7 tune tool , where does it go after you click on past with labels ??
Name:	high octain spark table.jpg
  3. #13
    Checkmark Show Units on each of the Data, Row, Col tabs.
  4. #14
    Quote Originally Posted by restless@westnet.com.au View Post
    got to here in 5.7 tune tool where does it go after you click on past with labels ??
    First, in the tunetool, on the table you're interested in, click in the top left blank tile (to select the whole table), do rightclick->Copy-with-Labels.
    Then on the Row and Col tabs, when you click Paste Labels, it pastes the axis labels/steppings for the Row or Col from the tunetool table (where you first did copy-with-labels);
    i.e. the Row and Col tab's Paste Labels button allows yo to quickly mimic a tunetool table (i.e. removes the work of having to painstakingly edit the axis steppings).
  5. #15
    I edited post #14, please re-read it.
  6. #16
    Aug 2008
    got here ?Click image for larger version.
  7. #17
    Aug 2008
    where is COPY SPECIAL ?
  8. #18
    Aug 2008
    Joe
    i can get the Generic maps in SCAN tool to change the values in the cells when i run one of my logs
    but i can't find in MAPS in SCAN tool the maps i copy with labels in TUNE tool ? (only the generic ones )
    don't they go into MAPS folder in SCAN tool after you copy with labels in TUNE tool ? do you have to save them some how in TUNE tool first
    cheers
  9. #19
    You have to highlight the whole table in the tunetool and do copy-with-labels, then you have to goto the scantool map, go into the map properties and on the Col and Row tabs click Paste Labels (without clicking on anything else along the way).
  10. #20
    Joe
    cheers
    After you create a map you have to save it (give it a filename)(and see which directory/folder it is going into).
    Post some more screenshots...
  1. EFILive is now Recruiting Software Build Testers
    By cindy@efilive in forum Do you want to be a Beta Tester?
    Last Post: March 20th, 2014, 12:19 PM
  2. LC1 Histogram logging
    By FreshDA9 in forum External A/D inputs
    Last Post: November 7th, 2012, 04:47 PM
  3. Looking for Software Version EFILive V7.5.6 Build 133
    By zimmerma323 in forum Duramax LLY
    Last Post: March 7th, 2011, 11:29 AM
  4. Problem with EFILive Scan Tool V7.5.4 (Build 6)
    By Kevin Doe in forum General
    Last Post: September 18th, 2008, 04:43 PM
  5. Histogram Plot
    By Black02SS in forum General
    Last Post: May 27th, 2005, 11:43 PM
