Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
Thread: how do i build a histogram in efilive ?
  1. #21
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    having another go at this
    some page shots first one in TUNE TOOLE Click image for larger version.
Name:	bobs spark table.png
    second one in scan tool Click image for larger version.
Name:	bob colum.jpg
    then i get this page Click image for larger version.
Name:	special colum.png
    i cant find copy special ??
  2. #22
    Go back to the tunetool, do copy-with-labels, come back to the scantool map Columns tab, click Paste Labels.
  3. #23
    Aug 2008
    hi joe
    ok i have done that , and run my log this is the result ??Click image for larger version.
Name:	bob spark page.jpg
ID:	18134 no idea what it means
  4. #24
    Ok, the axis interval steps on both axes match your B5101 Spark Advance table...
    now, see how your screenshot shows SPARKADV on the both axes (Row and Col)...
    so do this:
    - open the map properties;
    - goto the Row tab, checkmark Names, select RPM;
    - goto the Col tab, checkmark Names, select APCYL_DMA;
    - click Save, exit the map properties.
  5. #25
    Aug 2008
    do mean like this ?Click image for larger version.
Name:	no log file.jpg
    way is it that when i run my log the the name cylair grams gets a line through it ?
    what are the # that appear in the left column
    E38_0026.efi
    would you have a look at this log file for me and comment on the KR at low throttle openings at low RPM it seems to be getting a small amount from cyl C,E,F,G,H
  6. #26
    Lifetime Member darcy's Avatar
    Feb 2012
    Bob, you have the wrong pid trying to be selected for Columns, it needs to be be APCYL_DMA.
    If you have the 'Names' box ticked in the propeties, you'll be able to idenify it in th drop down list as {E38.APCYL_DMA}
    There doesn't seem to be any knock in that log from what I see.
  7. #27
    Aug 2008
    HI Darcy
    if you set the KR limits from 0.0 to 1.4 you will see it
    im buggered if i can find ( E38 APCYL .DMA in the drop down pid list on any of the column ,or row with names box ticked or unticked i do have it in my V2 though and works in my logs ?
  8. #28
    Feb 2012
    Knock <0.3deg in log E38_0026, Bob.
    Do you see this one highlighted blue?
    It's should be top of the list.
  9. #29
    Aug 2008
    no mate i dont have that one that i can find
    page shot of what i have
    i see you have your setting from 0. to 20 on your KR and cyl graphs im sure if you lower your high setting down to 1.5 you will see KR ? i used to run 5 as the high setting and dident notice anything either , what is considered as acceptable KR ? i thought none or less the .5
  10. #30
    Aug 2013
    Try this;
    Open your map properties.
    You'll see a bunch of tabs at the top... click on the Column tab.
    Now, you'll see a couple of boxes, one with the label "Names" and the other with the label "Selected".
    Untick the "Selected" box and tick the "Names" box.
    Your map properties should now look exactly like this...
    Your dropdown should now have everything available.
    Scroll up to near the top and locate E38.APCYL_DMA
    If you have an E38 log file already loaded in the scan tool, then you'll have to scroll down to near the bottom to find it...
  1. EFILive is now Recruiting Software Build Testers
    By cindy@efilive in forum Do you want to be a Beta Tester?
    Last Post: March 20th, 2014, 12:19 PM
  2. LC1 Histogram logging
    By FreshDA9 in forum External A/D inputs
    Last Post: November 7th, 2012, 04:47 PM
  3. Looking for Software Version EFILive V7.5.6 Build 133
    By zimmerma323 in forum Duramax LLY
    Last Post: March 7th, 2011, 11:29 AM
  4. Problem with EFILive Scan Tool V7.5.4 (Build 6)
    By Kevin Doe in forum General
    Last Post: September 18th, 2008, 04:43 PM
  5. Histogram Plot
    By Black02SS in forum General
    Last Post: May 27th, 2005, 11:43 PM
