Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
Thread: how do i build a histogram in efilive ?
  1. #31
    Quote Originally Posted by restless@westnet.com.au View Post
    do mean like this ?Attachment 18137
    way is it that when i run my log the the name cylair grams gets a line through it ?
    what are the # that appear in the left column
    Attachment 18138
    Attachment 18139
    would you have a look at this log file for me and comment on the KR at low throttle openings at low RPM it seems to be getting a small amount from cyl C,E,F,G,H
    The map shows CYLAIR with a line thru it, which means the pid CALC.CYLAIR is not selected... (it also needs SAE.MAF to be selected).
    I thought your B5101 table showed E38.APCYL_DMA as the link pid, this is what darcy said above... your log contains this pid, so change your map to use this.
  2. #32
    HI Darcy
    if you set the KR limits from 0.0 to 1.4 you will see it
    Attachment 18140
    Attachment 18141
    im buggered if i can find ( E38 APCYL .DMA in the drop down pid list on any of the column ,or row with names box ticked or unticked i do have it in my V2 though and works in my logs ?
    That amount of KR is very low, I'm wondering if you're really getting knock.
    +1 what darcy and statesman said above...
    checkmark Names (just below the drop down) and Selected (E38.APCYL_DMA is already selected, I see it in your log, and I see it in the drop down), and in the drop down it will be near the top ("air flow grams/cyl" and shows E38.APCYL_DMA) with Selected checkmarked.
  3. #33
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    hi Guys
    i think i have it NOW hopefully
    page shot
Name:	my histo.jpg
    now the big question ? what do the # in the map mean
    yes im wondering if it is false knock to ?
  4. #34
    hi Guys
    page shot
Name:	my histo.jpg
    You got it
    see on the map toolbar the button labelled n is clicked... this shows the hit count in each cell; click the button x-bar (x with bar over it) to see each cell's averaged value (for its values over its hit count).
    ( the up-arrow and down-arrow buttons show max and min values for each cell )
  5. #35
    Aug 2008
    HOW do i get this page up
Name:	spark map with graph.jpg
  1. EFILive is now Recruiting Software Build Testers
    By cindy@efilive in forum Do you want to be a Beta Tester?
    Last Post: March 20th, 2014, 12:19 PM
  2. LC1 Histogram logging
    By FreshDA9 in forum External A/D inputs
    Last Post: November 7th, 2012, 04:47 PM
  3. Looking for Software Version EFILive V7.5.6 Build 133
    By zimmerma323 in forum Duramax LLY
    Last Post: March 7th, 2011, 11:29 AM
  4. Problem with EFILive Scan Tool V7.5.4 (Build 6)
    By Kevin Doe in forum General
    Last Post: September 18th, 2008, 04:43 PM
  5. Histogram Plot
    By Black02SS in forum General
    Last Post: May 27th, 2005, 11:43 PM
