Originally Posted by
camaro10
What I was saying is I multiply the lambda by 14.2 for e10. That is the corrected afr than Id divide that corrected afr by the e38 afr? since the car will command 14.2 after the change is made for stoich
Ah, ok, I see what you're saying, yes you are correct ( sorry I'm being a bit thick )...
the BEN portion of the calc pid should multiply by (14.2/14.55), see below;
Code:
*CLC-00-003
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 8.0 18.0 .3 "{CALC.NTK1.V}*2.75+7.625"
LAM .5 1.5 .4 "{CALC.NTK1.AFR}/14.55"
BEN .5 1.5 .4 "{CALC.NTK1.AFR}/{E38.AFRATIO}*14.2/14.55"
*CLC-00-004
V 0.0 5.0 .1 "{EXT.AD2}"
AFR 8.0 18.0 .3 "{CALC.NTK2.V}*2.75+7.625"
LAM .5 1.5 .4 "{CALC.NTK2.AFR}/14.55"
BEN .5 1.5 .4 "{CALC.NTK2.AFR}/{E38.AFRATIO}*14.2/14.55"
And of course set your tune's stoich to 14.2.
EDIT: THE NTK USER MANUAL IS WRONG, IT SHOULD USE 14.7 AS STOICH
( THEREFORE USE 14.7 INSTEAD OF 14.55 IN YOUR CALC PIDS )
NTK's user manual incorrectly assumes 14.55 for stoich
it has now been confirmed that NTK uses 14.7 for stoich.
