Trying to control a 2006 4l60E with I.S.S added, with a 2010 TCM, will this work? there pressure manifold and 3-2 timing solenoid, external range switch were eliminated in 2009, and replaced with a internal range switch.
I've tried to turn on P0787 with HTP, then used Efi live to enable all the DTCS for the shift timing solenoid, the TFP pressure manifold, and the external range switch, then disabled the codes for the internal range switch. I'm hoping this works.
Otherwise will the Trans care if the pressure manifold was left disconnected? Along with the 3-2 timing solenoid Po787 be left unplugged as well? And will the external range switch work as the internal?
