Results 11 to 20 of 30
Thread: Vats
    Nov 2005
    Have you tried wiring in a dummy relay to the starter relay control circuit? Or put a resistor in line? So the ECM thinks a starter relay is connected.
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Aug 2010
    Yes
    Nov 2005
    Quote Originally Posted by shay View Post
    Yes
    ok and even with the starter relay wired in, it still wont start?
    So this is what your current setup is, corrrect me if Im wrong:
    Standalone harness
    VATS disabled with EFILive
    dummy relay wired into the starter relay circuit to the ECM
    no BCM
    no theft deterrent module
    manually jumping the starter solenoid so that the engine cranks
    And then the engine doesnt fire?
    12.9s @ 108 mph
    Nov 2005
    https://www.youtube.com/watch?v=hVMh3Div9yk
    Theres an LML swap.....but I dont know if they transplanted the entire dash/steering column/theft deterrent module, etc.
    12.9s @ 108 mph
    Nov 2005
    Well Im beginning to think that there is a more complex fuel-enable routine in the LML ECM....and its not just a simple VATS switch.
    Anyone up for working on an E38-style VATS patch for the LML ECM?
    12.9s @ 108 mph
    Aug 2010
    Standalone harness
    no BCM
    Hi
    It is not Standalone harness.
    I try on chevrolet silverado 2012 LML with OS 12644094.(no harness change)
    I disabled VATS with EFILive and disconnect the theft deterrent module connector:
    Engine not crank I try to jumper the starter relay and it's not start.
    I try more 4 OS with disable VATS - same.
    I try global A in EFILive same.
    You don't think I need to disable VATS DTC
    shay
    Nov 2005
    Last ditch effort would be to wire in a resistor across the ECM relay control terminals (the terminals for the coil of the relay)...and then try jumping the starter terminals of the relay.
    That way the ECM still thinks it has the relay wired in.
    If that doesnt work, than we're screwed...and going to need a VATS OS patch, similar to the late-model GM gas controllers (E38/E67/E92).
    Ross I know you havent worked on the LML in a while, but is there any chance you might be willing to look into this? Maybe some of the VATS/fuel-enable routines in the later E38/E67/E92 controllers carries over to the LML?
    12.9s @ 108 mph
    Apr 2006
    I've swapped ecms in LML trucks without issue by turning off the vats. These were complete trucks though. Something to add that was very weird, the one truck had a code issue and wouldn't clear so I swapped the ecm out of my truck and installed into his truck. The codes then came up and corrupted my ecm and wouldn't clear. Took a Tech2 flash to fix both ecms, must of been another module in his truck.
  9. #19
    Nov 2005
    Quote Originally Posted by IdahoRob View Post
    Rob I think its when the BCM and Theft Deterrent Module are removed/unplugged (IE, in a true standalone setup) that the LML ECM gets grumpy...
    Have you tried unplugging the theft deterrent module in your truck and then tried starting it?
    12.9s @ 108 mph
  10. #20
    Dec 2012
    Sounds like them CAN messages. Its possibly looking for a message that its not receiving because the module is no longer there, and its causing the ECM to freak out. Thats my best guess at the moment.
    Josh
    '04 GMC LLY
  1. VATS removal
    By jah81592 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 22nd, 2013, 10:25 AM
  2. what is vats patch and how do i use it
    By 400ss in forum Gen IV V8 Specific
    Last Post: July 5th, 2012, 09:10 PM
  3. Vats
    By Yortt in forum General (Petrol, Gas, Ethanol)
    Last Post: December 5th, 2010, 12:21 PM
  4. VATs question
    By Cougar281 in forum General (Diesel)
    Last Post: June 18th, 2009, 08:29 AM
