Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Vats
  1. #21
    Quote Originally Posted by DURAtotheMAX View Post
    Anyone up for working on an E38-style VATS patch for the LML ECM?
    Not possible even if we found the routine, the OS is RSA protected, no code mods can be done.
    Ross I know you havent worked on the LML in a while, but is there any chance you might be willing to look into this?
    Unfortunately I cannot do anything right at the moment, I have too many irons in the fire already.
    Maybe some of the VATS/fuel-enable routines in the later E38/E67/E92 controllers carries over to the LML?
    Not a chance, Bosch is Bosch code, not GM code.
    Has the original poster checked DTC's?
  2. #22
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    hmmmmm....that is extremely unfortunate.
    Shay, have you tried disabling the CAN receive/transmit ID tables in EFILive?
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  3. #23
    Nov 2005
    12.9s @ 108 mph
  4. #24
    Aug 2010
    The vats disable according to Efilive not support
  5. #25
    Nov 2005
    Quote Originally Posted by shay View Post
    Where does it say VATS disable with EFILive is not supported?
    Did you try disabling those CAN messages in the picture I posted?
    12.9s @ 108 mph
  6. #26
    Aug 2010
    They say it's not support:I have confirmed with development that at the moment the VATs disable does not appear to be functional for the LML. At the moment there is no workaround for this sorry.
    I try to disebale can not work
  7. #27
    Nov 2005
    That is frustrating...did you disable ALL of the CAN messages? Both transmit and receive messages?
    12.9s @ 108 mph
  8. #28
    The data pattern to disable VATS on these matches what Bosch had in the LBZ/LMM, if it doesn't work then there is probably little we can do to fix it at the moment.
  9. #29
    Aug 2012
    is this a replacement engine and computer into a chevy/gmc truck or a stand alone engine into seperate project?
  10. #30
    Lifetime Member Chavez91's Avatar
    Dec 2012
    Standalone
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
  1. VATS removal
    By jah81592 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 22nd, 2013, 10:25 AM
  2. what is vats patch and how do i use it
    By 400ss in forum Gen IV V8 Specific
    Last Post: July 5th, 2012, 09:10 PM
  3. Vats
    By Yortt in forum General (Petrol, Gas, Ethanol)
    Last Post: December 5th, 2010, 12:21 PM
  4. VATs question
    By Cougar281 in forum General (Diesel)
    Last Post: June 18th, 2009, 08:29 AM
