Results 1 to 9 of 9
Thread: cant pull stock tune off lly
    Oct 2009
    Default cant pull stock tune off lly
    Iam trying to pull stock tune off an lly and cant get it to pull. Ive puled the radio fuse and still nothing are there more fuses I need to pull and try again. the first time it said bootloader rejected no reply and after the radio fuse was pulled is just said boot loader rejected returned to normal operation. what can I do ?
    Mar 2009
    Does it have an aftermarket radio in it? If so, you need to physically unplug the radio adapter/door chime harness. I've tried pulling fuses and what not, but LLY's are picky and only go through for me if I actually unplug the adapter.
    Oct 2009
    Yea it has aftermarket radio In it so I need to pull it out do I need to pull any more fuses
    Jun 2011
    Pull radio, info, radio amp fuses. un click high speed. Sometimes it works. If not then next option is pull radio. If it has aftermarket remote start unhook wires from OBD2 port
    Oct 2009
    ok I pulled the gps and Bluetooth and radio out but it still says bootloader rejected
    Feb 2012
    Make sure the door is closed and the dome light is off. I have had a few LB7's and LLY's give me trouble when the dome light was on.
    Oct 2009
    ok well I got it to pull the stock off but now it wont take a full flash it says conditions not correct or request sequence error $22 so what does that mean
    You have something on the data bus causing all your issues, is there any way you can start to isolate things?
    Chances are if you can't read the ECM without issues then a reflash will no doubt fail too.
    Oct 2009
    ok I just found out it had an remote start on it. so I need to pull the radio out and gps and bluetoohth and the remote start and then go from there. that's all he said the he knew was on it
  1. 2004.5 LLY Stock Tune File Needed
    By BigTexas68 in forum Duramax LLY
    Last Post: May 20th, 2013, 02:23 AM
  2. Replies: 10
    Last Post: July 7th, 2012, 06:52 AM
  3. ANOTHER LLY Problem, (cant pull stock file)
    By TRUBBS in forum Duramax LLY
    Last Post: June 3rd, 2012, 01:53 PM
  4. Can't read stock tune out of LLY ECM
    By JoshH in forum Duramax LLY
    Last Post: March 13th, 2012, 09:38 AM
  5. cant pull the stock file
    By saltflat in forum Vortec V6/V8 Specific
    Last Post: June 2nd, 2009, 01:10 PM
