Results 1 to 9 of 9
Thread: What's the Best way to go from a HPTuners Custom OS to EFI Live COS?
    Apr 2007
    Default What's the Best way to go from a HPTuners Custom OS to EFI Live COS?
    I am considering making the switch from HPTuners to EFILive - I have used HP Tuners for years on several cars. I have some new projects that EFI Live would be helpful with but I have one existing car with a lot of tuning time into it that I would want to change over. It is a LS1 0411 2 bar SD tune.
    From what I can gather there s no way to convert directly from a HP Tuners custom OS to EFI Live, does that mean that I have to go table by table and manually make the switch? Not a huge problem but a PITA.
    Any advice would be appreciated.
    Thanks!
    Dec 2014
    Total re-flash and re-enter all data.
    Jan 2006
    What I do in those situations is flash the pcm back to stock with HPT, compare the stock tune to my HPT 2 bar tune and copy over everything that will copy. Theres only a couple things that don't copy like your VE table. I then flash that into the pcm with HPT and read it out with EFI Live. Its not 100% perfect but it saves you some time vs copying everything table by table. Then in efi live compare your new (hpt tune) to stock and check all the tables that are different to make sure they look right. It takes a little time but its better than hand copying every table.
    Apr 2007
    Great idea. Thanks.
    I was hoping for an automated solution but it looks like there isn't one.
    Senior Member mowton's Avatar
    Oct 2008
    excel transpose feature is great for moving form hptuners to efilive and back..
    Ed M
    Jan 2006
    Quote Originally Posted by mowton View Post
    Ed M
    I just use efi live to transpose it, works great
    Oct 2008
    Quote Originally Posted by minytrker View Post
    How does EFILive transpose the HPTuner formatted tables....interested.
    Ed M
    Jan 2006
    Convert data between units tab (Control+Alt+Enter)
    Oct 2008
    Wow after all these years I never saw that feature....thanks pretty cool....
    Ed M
  1. Replies: 11
    Last Post: February 29th, 2012, 03:35 PM
  2. HELP!!! Converting Efi Live to HPTuners file!
    By 06x6spdGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2010, 12:46 AM
  3. Switching from HpTuners to EFI live???
    By exploder in forum Gen III V8 Specific
    Last Post: November 4th, 2008, 05:22 PM
  4. EFI LIVE & HPTUNERS compatibility?
    By Rich Z in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2008, 11:46 AM
  5. HPTuners is fired. Please help me setup w/EFI Live
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: July 28th, 2007, 03:38 PM
