Results 1 to 4 of 4
Thread: Question on Auto Ve tuning
    Apr 2006
    Default Question on Auto Ve tuning
    Followed the tutorial did the logging updated the VE but the tutorial just leaves you there... I am assuming I just make the adjustments to the VE tables and change everything back(connect the maf, enable mil's ect) right?
    Is there a tutorial on how to tune the Maf, PE, and spark tables?
    99 C5 6speed LS2 402ci DTE 3.90 diff w/hardened output shaft, FLP headers, No Cats, ZO6 mufflers, Haltech Cobra CAI, Ported Fast 90 and LS2 TB, 42 Delphi, ZO6 Maf, EFI-Live, LC-1 wideband, Comp XE-r 232/236 .598/.605 112+0 lsa, AFR 205 heads milled .036 w/ Cometic .045 gaskets, TR 7.4 pushrods, textrila clutch, ASP underdrive pully, 490rwhp/474rwtq 10.83@130.6 1.59 60ft
    10.96 video
    in car vids
    10.9 runs
    After doing VE table do this:
    0. in OLSD tuing mode, log GM.DYNAIR to use to sanity check item 2. below or as a starting point for item 2.
    1. re-enable PE table and set the AFR/EQ that you want, log with wideband and see if it agrees;
    2. go back to OLSD tuning mode (no PE, no CL) and enable MAF, log MAFFREQ, AFR, WBO AFR, and do WBO AFR % correction procedure on MAF table (same as when you did it to VE table, except now your BEN map is X vs MAFFREQ where X is anything you logged (e.g. RPM 1 cell wide 0-8000));
    3. go back to OLSD tuning mode and enable CL and see if trims are on 0%.
    4. enable PE, CL, MAF and see what trims are and compare with wideband.
    5. goto a Custom OS and transfer your tune over and/or tune some more.
    Your running options:
    a. OLSD (uses VE+OLFA)
    b. CLSD (uses VE+trims)
    c. OLSDPE (uses VE+OLFA+PE)
    d. CLSDPE (uses VE+trims+PE)
    e. OLMAF (uses VE+MAF+OLFA)
    f. CLMAF (uses VE+MAF+trims)
    g. OLMAFPE (uses VE+MAF+OLFA+PE)
    h. CLMAFPE (uses VE+MAF+trims+PE)
    i. some combination of above in COS.
    The CL modes use the OLFA table whenever in OL.
    Apr 2006
    newbie questions....
    going right from the OLSD tuning what table exactly do I re-enable? Just B3605 and 3618?
    from the OLSD just enable c2901, 2902, 2903, 6002 and leave the rest the same?
    b4205 only?
    10.96 video
    in car vids
    10.9 runs
    Set B3618 to the AFR or EQ that you want; leave B3605 the same as for OLSD tuning (you can fine tune your non-PE AFR in B3605).
    Yes, correct.
    b4205 only?
    B4205 and B3801.
  1. Auto VE Map question
    By nchristian in forum Gen III V8 Specific
    Last Post: May 15th, 2009, 04:43 AM
  2. auto ve question
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2008, 03:14 AM
  3. COS 5 and Auto VE Tuning Question
    By RacerChris in forum Custom Operating Systems
    Last Post: June 15th, 2007, 03:49 PM
  4. Auto VE Question
    By bsteff in forum Gen III V8 Specific
    Last Post: March 18th, 2007, 03:21 PM
  5. Auto VE tuning question (long)
    By Ira in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2005, 08:38 AM
