Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Fuel Injector Speadsheet For LS3 to LS1 Injector
    Feb 2008
    Default Fuel Injector Speadsheet For LS3 to LS1 Injector
    I am looking to find a spread sheet to get the fuel tables out of a 2012 tune into a 411 pcm.
    I have found a couple of sheets but they all are for table B1210 that stops at 640 kpa (which is 2010 and older?)
    The tune Im trying to use goes to 768 kpa. (2011ish)
    Attached is the tune I am trying to use the fuel injector tables from. (the newer OS) and the other tune is what I am trying to get them into (the older tune)
    Sorry if this doesn't make perfect sense.
    Lifetime Member darcy's Avatar
    Feb 2012
    Those values are irrelevant anyway.
    0>80 in '411 = 400 >480 in E38 (assuming 4bar base fuel pressure)
    Senior Member mowton's Avatar
    Oct 2008
    Oct 2008
    Hey Joe, how is it going? Hope all is well, any neat projects lately. Wife and I retired and moved to Florida to start our next life...moved away from all the north east snow.....just in time :-)
    I started with the same files and modified them to work with both software's and also to show lb/hr which I am more comfortable with :-)
    Ed M
    Feb 2008
    Joecar, can i just copy and paste the LS9 B1210 table into the speadsheet and have it put in the right numbers on the LS1 Table?
    Just trying to figure out how to use your speadsheet.
    Thank that is exacly what I was looking for!
    Quote Originally Posted by mowton View Post
    Ed M
    Hey Ed,
    Good deal, I wish you well on your retirement, keep on doing car stuff
    Lol, I was laid of my day job in July 2014, so I did a few email tunes, I even did a few CNG tunes; at the moment I'm going thru my 2001 TA to replace worn out parts (all over), and I'm trying to write a tuning tutorial starting with Calc.VET (also showing how to setup wideband and maps), it's a lot of work and is going to take some time... and in February 2015, I got my day job back so now I'm working again.
    I saw that you added tables for HPT... I simply added the zip file in case someone wants tables for the other injectors (and lol so I could find it).
    Quote Originally Posted by kostelacd69 View Post
    No...
    copy the LS9 table (copy a block that includes the labels/headings) and in the tunetool do paste-with-labels into the LS1 table (the spreadsheet tab tells you which LS1 table)
    ( i.e. the spreadsheet contains static tables that have been interpolated to fit the LS1 tables )
    Feb 2008
    Cool got it, didnt know if I was missing something. Thanks again!
    Actually, each tab in the spreadsheet contains 2 tables: the LS9 table (marked "LS9"), and the LS1 interpolation of that table (marked "LS1")...
    so you would copy the LS1 table into your tune.
  1. LS1 Injector Data E38 PCM?
    By IJ. in forum Gen IV V8 Specific
    Last Post: July 23rd, 2014, 08:22 PM
  2. LS9 Injector Install In LS1, Injector Flow Rate Question
    By SLP IROC-Z in forum Gen III V8 Specific
    Last Post: June 11th, 2014, 05:16 PM
  3. Replies: 10
    Last Post: September 27th, 2013, 12:25 AM
  4. Ls1--ls6 injector flow rates
    By tblu92 in forum Gen III V8 Specific
    Last Post: September 25th, 2008, 03:26 AM
  5. Injector Offset ?'s vs LS1 edit
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2006, 11:06 AM
