Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Known issues with Mar 03, 2015 release of the EFILive software and firmware.
    Apr 2006
    Can the correct firmware be added to the March pre-release so our customers don't have to find another link off of the efilive.com site? Thank you,
    You should be saving that file to \My Documents\EFILive\V8\Config instead.
    Very good point.
    Jun 2012
    YES!!! Worked like a charm on the E60 I was trying to tune! Thanks guys~!
    Quote Originally Posted by IdahoRob View Post
    Sorry Rob,
    Each day since you posted this, I've planned to post an update but each day new issues crop up that prevent me (re)building the update. I expect to post a new update in the next day or two.
    Dec 2007
    Never had this error on an LMM before Script exited with code $0322: Conditions Not Correct or Request Sequence Error ($22) pulled fuses, unplugged, etc after attempting a full flash that failed truck will not start now not sure if its a March 03, 2015 issue or not?
    Quote Originally Posted by paint94979 View Post
    Have you installed firmware V2.07.81 as explained in Issue 4, here:
    https://forum.efilive.com/showthread...e-and-firmware
    Mar 2015
    After updating, all of my COZ and CTZ files are giving me "Error: $0185:file or folder not found" when trying to load onto the Autocal from EFILive Explorer, All files worked before the update, Any ideas?
    Error $0185 can be caused if the folder structure or file system on the AutoCal has been damaged or corrupted. Try reformatting the file system on AutoCal using the [Format Data] button on the [F3: Data Files] tab page in EFILive Explorer.
    WARNING: Performing a format will erase all data files on the AutoCal including all tune files and all data log files, so save copies of those files to your PC (if you can) before formatting.
  1. Known issues with Feb 14, 2015 release of the EFILive software and firmware.
    Last Post: March 3rd, 2015, 03:03 PM
  2. Known issues with Feb 09, 2015 release of the EFILive software and firmware.
    Last Post: February 12th, 2015, 08:04 AM
  3. Known issues with Feb 2015 release of the EFILive software and firmware.
    Last Post: February 9th, 2015, 11:53 AM
  4. Known issues with Jan 2015 release of the EFILive software and firmware.
    Last Post: February 4th, 2015, 06:55 PM
  5. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
