Can the correct firmware be added to the March pre-release so our customers don't have to find another link off of the efilive.com site? Thank you,
2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
1965 El Camino, duramax 9.6 @ 149MPH
All EFI tuned by Adrenaline Truck Performance
YES!!! Worked like a charm on the E60 I was trying to tune! Thanks guys~!
Never had this error on an LMM before Script exited with code $0322: Conditions Not Correct or Request Sequence Error ($22) pulled fuses, unplugged, etc after attempting a full flash that failed truck will not start now not sure if its a March 03, 2015 issue or not?
Have you installed firmware V2.07.81 as explained in Issue 4, here:
https://forum.efilive.com/showthread...e-and-firmware
After updating, all of my COZ and CTZ files are giving me "Error: $0185:file or folder not found" when trying to load onto the Autocal from EFILive Explorer, All files worked before the update, Any ideas?
Error $0185 can be caused if the folder structure or file system on the AutoCal has been damaged or corrupted. Try reformatting the file system on AutoCal using the [Format Data] button on the [F3: Data Files] tab page in EFILive Explorer.
WARNING: Performing a format will erase all data files on the AutoCal including all tune files and all data log files, so save copies of those files to your PC (if you can) before formatting.
