Results 1 to 3 of 3
Thread: need a tune for a 98 camaro a4 tune to load in a 6 spd car swapped to a4
    May 2007
    Default need a tune for a 98 camaro a4 tune to load in a 6 spd car swapped to a4
    any one have a stock tune i can load the transmission tables into a friends car? he has a shift kit so i need stockish pressures for sure and i can tweek the rest to get him going. then we can adjust as we go. thanks, chad.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    May 2007
    Thanks joe. I used one i found off tech for a stock 98 a4.
    2000 NBM trans am.
  1. LB7 unable to load tune.
    By bad_z28 in forum Duramax LB7
    Last Post: July 28th, 2012, 09:01 AM
  2. How to communicate with swapped pcm to tune?
    By FirstGenThree in forum Conversions / Aftermarket Parts
    Last Post: July 18th, 2012, 02:24 PM
  3. Help! trying trying to load tune
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 25th, 2011, 06:10 AM
  4. Help, can't load tune with efilive
    By rush in forum Duramax LB7
    Last Post: November 6th, 2008, 02:57 PM
  5. 07 escalade vvt w/ a 07 cts-v 6 spd tune
    By nycblazer in forum Gen IV V8 Specific
    Last Post: May 12th, 2008, 10:53 PM
