Results 1 to 7 of 7
Thread: CTSV Stand alone Help Please
    Feb 2015
    Default CTSV Stand alone Help Please
    Hi, I am a new to tuning so I am jus trying to start with the basics (make the engine run first). I am working on a 68 Camaro engine swap for a friend. I started with a 2010 Camaro L99 W/6l90 and added the LSA SC, LS9 cam, Deleted DDOD & VVT. I purchased a E67 and full flashed a 2011 CTSV stock tune. I have flashed in the VATTS Patch and tired all different combos (Type 1,2,&3) and cant get the engine to crank. I have read the DTC,s after each attempt and al ways have the codes in the attached file. I am thinking that the Throttle pedal is not compatible (2010 L99). can someone please take a look and point me in the right direction? Thanks Drew
ID:	18094   Click image for larger version.
    Feb 2015
    Quote Originally Posted by drewmorris7876 View Post
    Hi, I am a new to tuning so I am just trying to start with the basics (make the engine run first). I am working on a 68 Camaro engine swap for a friend. I started with a 2010 Camaro L99 W/6l90 and added the LSA SC, LS9 cam, Deleted DDOD & VVT. I purchased a E67 and full flashed a 2011 CTSV stock tune. I have flashed in the VATTS Patch and tired all different combos (Type 1,2,&3) and cant get the engine to crank. I have read the DTC,s after each attempt and al ways have the codes in the attached file. I am thinking that the Throttle pedal is not compatible (2010 L99). Can someone please take a look and point me in the right direction? Thanks Drew
    I forgot to add I am using a wiring harness from Current Performance wiring (no starter relay, no fuel control module, Rear O2's deleted). I have voltage to the injectors and spark to the plugs just not firing the injectors.
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Did you try wiring in a dummy relay on the starter control circuit?
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Feb 2015
    No I didn't try that. Do you know what pin that would be on the E67?
    Or.....
    {G1220} Starter Relay Type - change to 'Not Used'
    But looking at that list of faults you have bigger issues to fix first, looks like you are missing a 5V reference circuit as many critical sensors are coding 'Low Voltage'
    Feb 2015
    Do you think a bad ECM could be causing this? I am also getting P0606.
    I would try to get GM's TIS2WEB to flash it with the CTS-V program, then disable what you need in EFILive, that way you can rule out any issues with the ECM programming.
    There is sections in the E38 and E67 ECM's that no aftermarket programs can program, TIS2WEB will make sure these are programmed correctly for the LSA you have.
  1. Can VVT be enabled on a non VVT tune? E67 2007 CTSV
    By 04colyZQ8 in forum Gen IV V8 Specific
    Last Post: April 2nd, 2017, 05:57 PM
  2. 2012 CTSV Maf scaling, open loop issues.
    By ditosmotors in forum E37, E38 & E67 PFI ECM's
    Last Post: June 27th, 2012, 02:37 PM
  3. 2011 ctsv
    By panzerwillie in forum E37, E38 & E67 PFI ECM's
    Last Post: August 31st, 2010, 05:01 PM
  4. First ever 2009 CTSV dyno numbers before and after EFILive tune.
    By wait4me in forum E37, E38 & E67 PFI ECM's
    Last Post: February 23rd, 2009, 07:09 AM
