Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 74
Thread: A40 Full Read option
  1. #61
    Dec 2005
    On to those pesky "T" controllers, thanks for the efforts
    www.mscservices.net
  2. #62
    Jul 2008
    Hi Ross,
    Updated to today's current version [EFILiveV8.2.16_Setup.exe], which apparently clashes with your A40_R_Full.obj script. Get Error $0503: Script file not valid. Do you think you could post R_Full script that works with current V8 version?
    Thanks,
    Alex
  3. #63
    I'll have to dig through some back ups at some stage, certainly on my current PC I don't have the script that allows a full read.
  4. #64
    Jul 2008
    OK, thanks. Attached is your old script if that may help.
    -A
  5. #65
    The old script doesn't help, I just need to find it on a backup somewhere......don't expect it ASAP
  6. #66
    Jul 2008
    of course. thanks for looking into it at all. please take your time, it's not urgent for me.
    thanks,
    A
  7. #67
    The one hour plus read time will still apply though , nice one Allison!
  8. #68
    Dec 2005
    IIRC the checksums never calculated correctly, it was a real big mess with the amount of hardware versions and the older A40 and the Newer T series controller made a mess of it.
    I know Kennedy and myself tried numerous times to get the full read and it would not save to a checksum that was correct.
    It would be awesome if if could be something we can get to read/save stable.
    www.mscservices.net
  9. #69
    Dec 2005
    www.mscservices.net
  10. #70
    I know, the checksum situation was odd in that some OS's would read perfectly every time, others were never correct. Like the miserable read processing in the TCM got it wrong or the OS's didn't actually have the checksums active and therefore the value was not correct.
    My findings were:
    15827766 = Passes
    10377105 = Always Fail
    25941751 = Always Fail
    25941752 = Always Fail
    Probably not possible, I'm told not even the factory Allison tool does full reads on the A40, it is the cal area only, I think that says it all.
  1. A40 full read?
    By vectorbundle in forum Allison 5 & 6 Speed
    Last Post: November 6th, 2014, 09:02 AM
  2. Read option for E35A and E35B in V8 Tune section.
    By Brian1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 8th, 2012, 10:21 AM
  3. Full Flash option greyed out.
    By carl0s in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2010, 07:24 PM
