Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 2012 Ram stock tune
  1. #11
    Apr 2015
    Quote Originally Posted by turk88 View Post
    ok, so I understand that now. so now my only thing is I still don't see my exact tune. also, is there a miss print on the website? I see to identical tunes, 12350331AN its listed twice.
    Turk88:
    Did you find the tune you were looking for, 12351331AM / N ?
    the depositfile site only has 2 copys of 12350331an.
    I am looking for the first tune as well.
    TNX
    crdth
  2. #12
    Feb 2015
    Quote Originally Posted by crdth View Post
    Turk88:
    TNX
    crdth
    Well, there is 2 different 12350331AN files on the site, one is described to be for a 2500 truck and the other is for a 3500 truck. My trucks a 3500 truck so I decided to flash that 12350331AN for a 3500 into my truck. Truck ran fine with it so I decided to run that as my base file. I know its not the exact file but I figured I would give it a try. I am not saying that it will work for you but it worked for me. But if anybody has the file 12351331AM or AN please share it bellow. hope that helps you out a bit.
  3. #13
    Apr 2015
    Hello Turk88:
    Good to see that it worked OK. I have been told that 12350331AN and 12351331AN when compared show as being the same. I am still not 100% convinced of that thou because I do not know all the other parameters that are NOT part of the compare, IE: transmission functions, gearing compensations, etc. If all were truely the same, I would think Dodge would NOT have assigned a differant part number for the 3500 4x4. When you're gonna mess with the ECM in a $65k truck and kill all warranty in the process, you want to be certain about the whole process. I will see if I can get the file from Techauthority, if I cannot obtain it anywhere else.
    TNX for the reply and the info given
    crdth
  1. Stock tuning file for 2012 6.7
    By dodgeram5-92500 in forum Diesel
    Last Post: January 8th, 2015, 09:50 AM
  2. HELP 2012 1.4L turbo Cruze tune
    By bstuder11 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 19th, 2014, 01:05 AM
  3. 2012 CTS-V - No Tune found
    By Meister in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 9th, 2012, 11:59 AM
  4. 2012 5.3 silverado knocking with stock tune
    By TravRMK in forum Gen IV V8 Specific
    Last Post: February 15th, 2012, 07:21 AM
  5. 2012 ZL1 Camaro Tune
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: February 11th, 2012, 03:33 AM
