Results 1 to 7 of 7
Thread: 2015 Cruise won't work
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default 2015 Cruise won't work
    Hey guys,
    I've got a 2015 LML we tuned, runs fine but the cruise doesn't work. I suspect it's in the base file sub segments... But wanted to know your thoughts on if it could be a different setting somewhere.
    The base OS we used matches on all segments, except:
    Fuel System: My OS 12653952 vs TIS OS 12653951
    Engine Diagnostic is one version older than the one TIS says was currently on his vin, but was used on that vin at one time so I assume it should work fine.
    Thanks!
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Lifetime Member Mitco39's Avatar
    Jan 2009
    Any mismatching segments will do that. Ive had issues with cruise and turbo brake not working whenever the segments did not match up perfectly.
    Mar 2015
    Hey guys i Baugh the efilive scanner and I click on the full flash and now a can not start on my durmax? Do someone now what I have do now?
    Jan 2009
    Who did you purchase the efi live from? They should be able to help you.
    Mar 2015
    It purchased on eBay!
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Call eBay.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Jan 2009
    I hope it wasnt one of these ones that Cindy was alluding to.
  1. 2015 file..work truck
    By House in forum Duramax 2011+ LML / LGH
    Last Post: January 3rd, 2015, 08:15 PM
  2. New PCM, A/C won't work and it's 104!
    By puddlestomper in forum Duramax LB7
    Last Post: August 31st, 2013, 04:50 AM
  3. How does the B3646 in the lean cruise work?
    By chevyguy7802 in forum Gen III V8 Specific
    Last Post: November 23rd, 2009, 10:55 AM
  4. VDASH won't work
    By zacksfoam in forum FlashScan V2
    Last Post: August 14th, 2009, 05:04 PM
