Results 1 to 2 of 2
Thread: 12V switching source on the E38 ecm... try pin 51
    Junior Member T2000's Avatar
    Mar 2010
    Default 12V switching source on the E38 ecm... try pin 51
    Whilst tidying up my wiring I was looking for a +12v switch wire for my LPG relay... so I went back to a wiring diagram I found earlier this week.
    Pin 51 on the E38 is labelled as "Fuel CTL-Sec" and in the wiring diagrams I have seen it is used to switch a fuel pump relay.
    Pin 51 is not populated in any of the PCM harnesses that I have seen (All Holdens) so I thought I would check to see if it could be used. And after popping a wire and connector into the Pin 51 cavity of C1/J1... viola - switched 12v
    As expected the wire is cold with ign off or in acc but is hot when ign is on.
    Shared for your benefit and so that I know where to find the info if I suffer another "grey moment"
    Credit to LSXworks and the E38 COS tutorial for the images that I have re-purposed in the following illustration.
Name:	E38 ecu Pin 51.png
    It is used for systems that have a secondary fuel pump, I think you got lucky that it functions, there may be some calibrations where it is disabled.
  1. 5 Volt Source available for the ECM for a potentiometer?
    By MDi632 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 5th, 2015, 03:42 PM
  2. E38 ECM 12V Power Consumption on the Bench
    By rkmason in forum Tips and tricks
    Last Post: November 9th, 2012, 12:21 PM
  3. 06 ecm pin layout???
    By comnrailpwr in forum Cummins 5.9L
    Last Post: June 16th, 2011, 03:56 PM
  4. help with ecm pin
    By justin123 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 16th, 2009, 04:00 AM
  5. ecm pin outs
    Last Post: January 7th, 2006, 04:05 AM
Tags for this Thread
