Results 1 to 1 of 1
Thread: e67 hitting a rpm limiter thats set way above the rpm its at
    Apr 2006
    Default e67 hitting a rpm limiter thats set way above the rpm its at
    have a e67 in a caddilac that is hitting some sort of limiter on the 2-3 shift.
    the trans is a 4l80 with a pcs tcm2000 controller
    attached is the tune and the log
    thanks
  1. Hitting Wall At 5000 RPM
    By scott30 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 16th, 2012, 07:27 PM
  2. Replies: 6
    Last Post: January 2nd, 2011, 12:08 AM
  3. Lowering the rpm limiter
    By olboy82 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 5th, 2009, 06:25 PM
