Results 1 to 6 of 6
Thread: 2011 cummins tuning questions
    Mar 2015
    Default 2011 cummins tuning questions
    hey guys my names aaron. ad i'm wanting to discuss the tuning practices on these 4th gen dodges. i had a 3rd gen 5.9 and understood that for the most part. and i would like to get on the road witht the factory ish files while i start tweeking my tune file on my free time.
    my current truck is 2011 ram 2500 srw 4x4 with the 6.7 cummins.
    i have found a stock tune file that someone has shared on the board here to another member.
    1. how do i verfy it is the correct file for my truck?(i have attached said file)
    2. on the file and did not see anything about dtc's so i can disable the codings for my obsolete dpf system and non functioning egr system. are the not present?
    3. i must load the stock tune into truck and then read the ecm?
    im sure i have something messed up here so far.
    like i said i would like to just get going with stock tune installed minus dpf/egr while i start tweeking and read in depth more
    Mar 2015
    Controller CMD CM2200 Cummins Diesel ECM
    VIN (Current) 3D7UT2CL5BG509032
    VIN (Original) 3D7UT2CL5BG509032
    ECM Serial Number 000000004524
    ECM Part Number 5268442
    Calibration ID 11350031AG
    Operating System 22110611
    Data Software 05150521AC
    Boot Software 00000000AA
    Cal Verification Number $5C88CA91
    Injector 1 Trim Code 8Z1AB
    Injector 2 Trim Code 81SEA
    Injector 3 Trim Code ASR1A
    Injector 4 Trim Code 81HWB
    Injector 5 Trim Code ASSLB
    Injector 6 Trim Code 8H87B
    Mar 2015
    http://kb.dcctools.com/index.php?Vie...6&AttachID=167
    after searching the above link i think i might have came up with the determination that the proper operating system i will need is going to be 11350130AM.
    as found on page 165. the above file i found appear to go to a
    2011.5 DD 6.7L CUMMINS AUTO 50S also found on page 165.
    DD - RAM 3500 CAB CHASSIS
    Quote Originally Posted by akarrerdonzi View Post
    http://content.efilive.com/documents...ck%20Start.pdf
    There is no emissions defeat parameters for the 2010+ Cummins in EFILive.
    We will include those parameters at some point for non US tuners.
    No, it is not possible to read the ECM via OBD-II, you can only flash in your tunes in.
    Mar 2015
    okay where can i find the factory files at? i seen the deposit files link but the dont have one thats meets the needs
    I would suggest contacting a tuner that can provide a base file and purchase one from them.
  1. CM2200A Cummins Questions
    By Chavez91 in forum Cummins 6.7L
    Last Post: November 6th, 2014, 02:37 PM
  2. 2011 Camaro 6l80 to 4l80 swap w vvt... questions
    By rubbersidedown in forum Gen IV V8 Specific
    Last Post: September 10th, 2013, 12:54 AM
  3. Tuning a Camaro 2011 A6 L99 questions.
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: November 5th, 2010, 12:33 PM
