Results 1 to 7 of 7
Thread: Used Vehicle with DSP5 switch
    Mar 2015
    Default Used Vehicle with DSP5 switch
    Hello everyone,
    I purchased a used 01 Duramax 3500 DRW. It has a DSP5 switch. There is a tune on it because the difference from position 1 to position 5 is night and day. I had the switch what I think is position 5, it's not marked, but the truck is an animal in that position. Well, I limped my trans on the interstate going up a hill when i hit WOT. I have no idea what tunes are on this, or for that matter what program it was tuned with. I was wondering since the tune is definitely programmed can I buy the OBD2 to RJ45 cable and use the EFI live scan and tune program? I appreciate any information you can provide. Thank you in advance.
    Senior Member KhakiCummins's Avatar
    Sep 2011
    In order to be able to tune it, you would need to buy a V2 with the GM Tuning option.
    http://www.efilive.com/flashscan
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Mar 2015
    Do you know if I can view what tunes are already installed? I was hoping that since someone already paid for the license that's tied to the VIN, that I wouldn't have to purchase an additional license or hardware
    Sep 2011
    DSP5 tunes cannot be read out of the ECM. The only way to get around paying for a new VIN license and hardware is to find who originally tuned it. They are going to charge you for any changes to the tunes though.
    Duane
    Mar 2015
    I kind of figured that. My issue is I don't know what tunes are on it and my guess is on 2 of the positions I'm pushing too much power. I will be towing a 15000 lb RV and it would be nice to know if there are lower HP tow tunes programmed. I'm not going to use the higher power selections as I don't want to do expensive trans repairs. At this point I may just go to the dealer and have them reflash the stock tune. I was hoping efi live would have a read only mode for the different tunes so you know what's been done. I'm disappointed to say the least.
    Moving thread to Diesel (General)...
    IIRC you can read out LB7/LLY DSPx tunes...know for a fact you cant on LBZ+ DSPx ones though.
    Also you need an EFILive FlashScan V2 or an AutoCal from a tuner to read them, no generic cable is able to be used with EFILive's platform.
  1. DSP5 switch no voltage
    By stevensca25 in forum FlashScan V2
    Last Post: January 6th, 2012, 10:39 AM
  2. how to switch tunes to DSP5????
    By browneflatwork in forum General (Diesel)
    Last Post: February 28th, 2011, 10:27 AM
  3. DSP5 on the V2 no switch
    By rcr1978 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 21st, 2010, 03:21 PM
  4. DSP5 Switch
    By foxracingfreak in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 9th, 2010, 01:14 AM
  5. Going from DSP2 switch to DSP5 switch
    By Dmax15 in forum Duramax LB7
    Last Post: February 23rd, 2010, 03:25 PM
