Results 1 to 7 of 7
Thread: fuel gauge problems
    Feb 2014
    Default fuel gauge problems
    I put a 04 pcm in my 03 Silverado now my fuel gauge is backwards any ideas
    Last edited by joecar; March 28th, 2015 at 03:10 PM. Reason: corrected thread title
    Just a guess, look at F0501 and other tables/parameters in the Fuel System segment.
    Also, find a stock 2004 Silverado tune file (www.tunefiledepot.com) and compare the Fuel System segment to your stock 2003 tune file.
    Feb 2014
    I copied tables over but it is still backwards I even inverted the settings but it didn't change it just wondering if it had a setting somewhere else
    Feb 2014
    this is the tune
    Aug 2006
    See if this helps.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Feb 2014
    Thanks lextech joecar was right i just didn't change all the settings its working right now.
    Thanks Jeff
  1. Problems with fuel gauge being inaccurate
    By sixltrbtr in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 26th, 2013, 05:37 AM
  2. Weird Fuel pump problems....
    By GAMEOVER in forum Conversions / Aftermarket Parts
    Last Post: September 4th, 2012, 06:35 AM
  3. Replies: 1
    Last Post: September 22nd, 2010, 03:40 AM
  4. lookin for gague pod??
    By 02dirty in forum General (Diesel)
    Last Post: June 16th, 2009, 02:43 PM
