Results 1 to 10 of 15
Thread: code 1400
    Oct 2009
    Default code 1400
    Not sure if this is in the right place. when I use the tunning tool and go to close it out I keep getting and error code ( system error code : 1400 invalid window handle) what does that mean?
    Which build version of V7 software (go Help->About)...?
    Can you post a screenshot...?
    Or when you see the popup, go Ctrl-C within the popup, and then immediately paste into a reply to this thread.
    Oct 2009
Name:	screen shot efi.jpg
    hope the screen shot worked
    Oct 2009
    its v7.5.7 (build276)
    EFILive Tune - Digital tools for onboard vehicle electronics
    System Error. Code: 1400.
    Invalid window handle.
    OK
    Do you want to try and see if it happens with build 280...?
    March-2015-EFILive-Release-Candidate-1
    Oct 2009
    ok its updated now as soon as I get the motor back in iam gonna try it . also my firmware wont update to new release iam on the 2.07.77 feb 05 2015. I refresh my firmware in v8 and it says it ok up to date?
    Quote Originally Posted by crash85 View Post
    If you haven't already, you must install the latest V8 software because the V8 software contains the updated firmware. The firmware should be updated to V2.07.81 after installing the V8 software and clicking on the [Check Firmware] button.
    Oct 2009
    ok I installed the new updates for the v8 and v7.5 and go to check my firmware and it still the same 2.07.77 feb 05 15. where am I messing up? I download the new update and then hit run . it then went and did its thing and said finish and then I check and its still the same
    To update the firmware do this: start V8 S&T and click Check Firmware, and look for red, click button to program new firmware.
    Then when done it will show you if the BBx config needs updating also, look for red and click button to program config.
    Oct 2009
  1. p 1631 code
    By MECHAN12 in forum E37, E38 & E67 PFI ECM's
    Last Post: April 6th, 2011, 04:02 PM
  2. System Error- code 1400
    By Tarkstoys in forum FlashScan V2
    Last Post: April 17th, 2010, 07:54 PM
  3. Err 1400, Invalid Window Handle
    By Mr. P. in forum Do you want to be a Beta Tester?
    Last Post: December 20th, 2009, 03:12 PM
  4. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 01:57 AM
  5. Error code
    By Toired Old Man in forum FlashScan V2
    Last Post: October 24th, 2008, 09:17 AM
